idlemind Riding on 17's
Joined: 15 Aug 2005 Tech posts: 1212 Location: Shifting with no clutching My 2NRide: Mitsubishi Touring Lancer
Posted: Fri Jul 04, 2008 1:29 pm Post subject: |
PM k.c.151 or JUS4SHO
i believe kc has coilovers, not sure what SHO had |
rainman Trinituner Peong
Joined: 25 Jul 2005 Tech posts: 469 Location: Back Offshore *sigh* My 2NRide:
Posted: Tue Jul 08, 2008 4:20 pm Post subject: |
| teichou wrote: | i called nr diamond and that is what i was told
i nearly sh!t myself
and i ain really trust buying a tranny from a parts dealer too many stories
that is why i decided to go manual before mine went bad |
they can be repaired for about 5-9k i would repair it and then sell it |
venum 3NE2NR Diesel Boyz
Joined: 07 May 2004 Tech posts: 3632 Location: San Fernando My 2NRide: Mitsubishi L200 Animal
Posted: Thu Jul 10, 2008 12:27 pm Post subject: |
I have to buy a 4G18 timing belt
I need one borrowed to compare
Anyone willing to lend
also if anyone know where I can a Gates Or Sun OR Unnita
also PS and alternator\compressor belts |
fras Chronic 2NR
Joined: 25 Aug 2005 Tech posts: 1146 Location: Tobago My 2NRide: Mitsubishi Mivec
Posted: Thu Jul 10, 2008 12:38 pm Post subject: |
changin all one time venum... sweet!
take ah service on time and u good to go  |
Posted: Thu Jul 10, 2008 12:45 pm Post subject: |
| venum wrote: | I have to buy a 4G18 timing belt
i have an old timing belt 4g18 pm meh we go link up but if you want to save some time the timing belt number is MD342154
http://www.protonparts.com....~TimingBeltKit%20temp.htm
if you changing everything you might as well change the crankshaft seal and camshaft seal |
Posted: Thu Jul 10, 2008 1:56 pm Post subject: |
Thanx for teh number
I may want the belt borrow still to compare it when I go looking for one |
Posted: Thu Jul 10, 2008 2:01 pm Post subject: |
yeah venum change those seals one time too, i had to run out and get mine after the belt and everything was off
yuh want the 4G93 equivalents orrrrrrrrrr?
Guys i need a Condenser Fan
DM quote meh $5914.52
i tell them HDMC....well not really  |
JUS4SHO 3NE 2NR Moderator
Joined: 22 Apr 2003 Tech posts: 9197 Location: N/A My 2NRide: LANCER
Posted: Thu Jul 10, 2008 4:35 pm Post subject: |
| working on sumtin 4 you ^^^ |
Posted: Thu Jul 10, 2008 4:36 pm Post subject: |
| ok mumford |
Posted: Thu Jul 10, 2008 5:15 pm Post subject: |
| idlemind wrote: | | yeah venum change those seals one time too, i had to run out and get mine after the belt and everything was off |
yup cam and crank seals will be changed as well
these cheap by DM
$60.00 i paid by DM for teh Crank oil seal when I had mine
can't remember for the CAM |
Posted: Fri Jul 11, 2008 1:25 am Post subject: |
| venum wrote: | Thanx for teh number
just let me know when yuh want to borrow/keep it i sold the cs3 so i dont need it...i'm going back offshore next week wednesday. so anytime before that will be ok. pm me and i will send my number. |
QG 18 pounds of Boost
Joined: 18 Jul 2006 Tech posts: 2342 Location: Cross-Crossing, San Fernando My 2NRide: Nissan Y11 AD WAGON
Posted: Sun Jul 13, 2008 12:25 pm Post subject: |
| ronsin1 wrote: |
last I heard was $17,000.00 that was ah couple of years ago |
what???? ouch. I drive a CS3A lancer (1.6 cvt) and very hard too. Like I have to stop driving on 6500rpm and ease down to 4000rpm. Them price real hot. And a front bumper for these lancer used is around $3000+. |
Posted: Sun Jul 13, 2008 3:55 pm Post subject: |
| ^^^^ 4000RPM kinda high as well. CVT's are very high maintenance, on the CS3 its recommended to change the fluid every 20000KM using the Mitsubishi Original Fluid. It can be very costly to repair or replace a cvt tranny. quick and sudden acceleration (stomping on the gas) will cause the drive belt in the tranny to heat up quickly and cause tranny failure. we also live in a tropical country which causes the tranny to heat up a lot quicker so installing an external oil cooler will help tremendously |
ronsin1 I LUV THIS PLACE
Joined: 30 Nov 2005 Tech posts: 1037 Location: bussin' jokes My 2NRide: Mitsubishi Lancer
Posted: Sun Jul 13, 2008 8:16 pm Post subject: |
| again with all that stress you putting your tranny through I would recommend a Transmission Cooler |
Posted: Mon Jul 14, 2008 1:45 am Post subject: |
hmm like is best i park up and travel, and doesn't these CS3 lancer use chain type CVT? Or does it vary?
I know Nissan uses the belt type. |
Posted: Mon Jul 14, 2008 7:31 am Post subject: |
CVT continuously controls the O-pulley diameter and changes the gear change ratio.
CVT makes for optimal tuning between the smaller pulley piston, discharge rate reducing oil pump, and the direct control torque converter by which an efficient engine output transfer and a smooth ride are realized. Based on accelerator travel information from actual drivers under actual driving conditions, the optimal efficiency point between the engine and the CVT was obtained and a supple and smooth driving feel is obtained under numerous conditions while also achieving low fuel consumption
Mitsubishi Motors
hope this answers your question |
Posted: Tue Jul 15, 2008 1:15 am Post subject: |
| Thanks! |
Posted: Mon Jul 21, 2008 11:09 pm Post subject: |
| ok my CS3A giving some problems at times the idle speed will be to low and hen at time it high around 2k.... TPS or the idle stepper motor |
Posted: Tue Jul 22, 2008 7:36 am Post subject: |
I was told it was the idle stepper motor when mine was doing same
but it sorted itself out
doh forget me with the timing belt - 4G15 GDI please |
Posted: Tue Jul 22, 2008 11:52 am Post subject: |
well strangely enough i had the car scanned today along with another cs3a all readings were identical no fault codes nutten, switched sensors etc car still going the same thing. i lost
belt no problem ... |
