dev51 Street 2NR
Posted: Tue Dec 19, 2006 11:45 am Post subject: |
| frass, I have experienced the same problem at 160...and I assume it is the speed cut.. I do have the K&N Drop in filter. It did make a noticable difference. I got it at a store in Valpark.. |
ronsin1 I LUV THIS PLACE
Joined: 30 Nov 2005 Tech posts: 1037 Location: bussin' jokes My 2NRide: Mitsubishi Lancer
Posted: Tue Dec 19, 2006 12:54 pm Post subject: |
| Quote: |
Whats the price of this looking for one... |
dev51 Street 2NR
Posted: Tue Dec 19, 2006 12:58 pm Post subject: |
| There is an auto place very close to the Supermarket in Valpark shopping plaza. That's where mine was bought. It's around $400 |
KiD 3NE 2NR for life
Joined: 16 Jan 2006 Tech posts: 224 Location: north, before d lighthouse My 2NRide: Subaru Forester
Posted: Tue Dec 19, 2006 2:20 pm Post subject: |
| i bought mine a long time ago when they werre hot paid $550 somewhere in valpark.however i never experienced the speed cut. after 170km it takes a while to go any further tho |
dev51 Street 2NR
Posted: Tue Dec 19, 2006 3:02 pm Post subject: |
| KiD, is your lancer local or RORO? |
Posted: Wed Dec 20, 2006 9:59 am Post subject: |
| roro |
dev51 Street 2NR
Posted: Wed Dec 20, 2006 10:07 am Post subject: |
| KiD, that may be why you're not experiencing the speed cut....i don't know why...not really sure, but mine is local... I also have the newer model lancer from the firm, and that only runs to about 165-170... |
fras Chronic 2NR
Joined: 25 Aug 2005 Tech posts: 1146 Location: Tobago My 2NRide: Mitsubishi Mivec
Posted: Wed Dec 20, 2006 6:28 pm Post subject: |
I got my K&N filter today and my car is roro
I'm also checking out a fuel pressure regulator from RPW... where can I have this installed and the speed cut removed  |
venum 3NE2NR Diesel Boyz
Joined: 07 May 2004 Tech posts: 3634 Location: San Fernando My 2NRide: Mitsubishi L200 Animal
Posted: Wed Dec 20, 2006 11:55 pm Post subject: |
K&N drop-in
bah . . .
will be building my on intake for both my CK and CS |
fras Chronic 2NR
Posted: Thu Dec 21, 2006 2:41 am Post subject: |
| venum wrote: | K&N drop-in
bah . . .
I'll like to see pics of ur CS install... the engine bay is so congested with the battery & Tranny. The only thing I can think about is running a straight pipe from the flex tubing after the TB to the grille  |
JUS4SHO 3NE 2NR Moderator
Joined: 22 Apr 2003 Tech posts: 9197 Location: N/A My 2NRide: LANCER
Posted: Thu Dec 21, 2006 8:23 am Post subject: |
| 160km sumtin wrong with all yuh car i hit 200 km easy 210 -220 does take ah lil time to come |
dev51 Street 2NR
Posted: Thu Dec 21, 2006 8:55 am Post subject: |
| JUS4SHO, with the 4g18 engine? that's strange....i mean, i can probably get 170 and a lil over, but that's after a long time.....i find the engine does be revving and the car doesn't go any more.... |
Posted: Thu Dec 21, 2006 8:57 am Post subject: |
| let me guess yuh just press out ent, so the rpm stuck @ around 6200 ? |
dev51 Street 2NR
Posted: Thu Dec 21, 2006 10:51 am Post subject: |
| JUS4SHO, nah, i kept the rpm a little below that...i realised that with this car, pressing down all isn't good. it just causes the engine to rev... |
fras Chronic 2NR
Posted: Thu Dec 21, 2006 11:57 am Post subject: |
| dev51 wrote: | | JUS4SHO, nah, i kept the rpm a little below that...i realised that with this car, pressing down all isn't good. it just causes the engine to rev... |
Depends... You could reach high speeds @ low rpm it would just take longer.
I would really like to drive a manual and see how it responds |
fras Chronic 2NR
Posted: Thu Dec 21, 2006 12:07 pm Post subject: |
FSE Fuel Pressure Regulator
HOW DOES THE POWER BOOST VALVE WORK?
The Power Boost Valve is a high performance tuning part which replaces the original equipment valve (fitted to the vehicle). A range of models are available to suit a wide variety of European cars, which almost certainly includes yours. We are continually developing new designs to expand the number of applications. We outline the benefits of the Power Boost Valve by drawing a comparison evaluation: Ref: Original Equipment Fuel Pressure Control Valve
The electric fuel pump supplies fuel at a high pressure to the fuel rail and injectors, which is then regulated by a fuel pressure control valve. Typically, the regulator is not adjustable and is pre-set to a 3 bar maximum pressure. At idle the fuel pressure valve reduces it by 0.5 bar approximately to 2.5 bar. When accelerating quickly from standstill the fuel pressure increases at a proportional rate retaining a lean fuel mixture strength as required by the E.E.C. for new vehicles. However, the resultant effects of the standard valve produce:
1:- lethargic throttle response
2:- occasional driveability problems at slow traffic speeds
3:- intermediate performance 'flat spots' when accelerating (Most noticeable on MAP sensor model cars and newer return less fuel rail systems)
Firstly, this valve has an adjustable fuel pressure, effected by the movement of an adjustment screw on the crown of the unit.
New Power Boost Valves are pre-set with a maximum fuel pressure of 2.5, 3.0 or 3.5 bar, depending on the vehicle in question, and similarly (to the original valve) the fuel pressure is reduced by 0.5 bar approximately at idle. There the similarities end.
On acceleration from standstill the Power Boost Valve fuel pressure will increase at 1.7 times the standard rate. This will produce a healthy, strong fuel mixture strength which will instantly improve the drivability of your vehicle, providing:-
1:- instant throttle response
2:- removal of performance flat spots
3:- faster acceleration
4:- extra engine performance
1:- The kit comes supplied with the adapter to fit into the fuel rail for most model vehicles and cover the whole Mitsubishi range.
2:- The kit comes supplied with the fuel pressure gauge for easy adjustment (Fitted inside engine bay only)
3:- This kit is compatible with both naturally aspirated (Recommended) and turbocharged cars (Highly recommended) |
dev51 Street 2NR
Posted: Thu Dec 21, 2006 3:28 pm Post subject: |
| frass, I agree with you...I would love to see how the 4g18 will perform when coupled to a gearbox.... any idea on how much for the Fuel Pressure Regulator.... |
fras Chronic 2NR
Posted: Sun Dec 24, 2006 2:01 pm Post subject: |
with that regulator you shpuld consider a free-flow intake since fuel does not make power
air does
combine better fuel delivery with increased breatheability and you have better performance |
fras Chronic 2NR
Posted: Wed Dec 27, 2006 9:45 am Post subject: |
| JUS4SHO wrote: |
as with body parts expensive just like any newer model car, bobby's in d bamboo have body parts cheap, also kawal singh in chaguanas supplys diamond motors with a lot of mechanical parts (which you pay big $$$ for and its not oem)
You have a number for Singh  |
