Nah, it was checked with gauges and thing..right through..nismo i had d same problem with d primera it was because the compressor was not gased up properly it was not full
Valve..hmm...how can I check that valve!!the valve under the dash by the evaporator may be defective this is what controls the airflow into the evaporator so if you say the line inside the dash not getting cold than the valve may be sticking
