richiepooh Chronic TriniTuner
Posted: Thu Jul 02, 2009 6:21 pm Post subject: External Hard Drive & USB deck |
| Could an External Hard Drive work with a USB Deck e.g. Pioneer Head Unit?? |
southside connections Shifting into 6th
Posted: Thu Jul 02, 2009 6:40 pm Post subject: |
| hmmm good question, i really wonder dread? |
Soundstream_626 I LUV THIS PLACE
Joined: 13 Mar 2005 Tech posts: 903 Location: san juan My 2NRide: Nissan Y 11 Wingroad
Posted: Thu Jul 02, 2009 7:20 pm Post subject: |
great enough vibrations can damage the platters on hard drives
so even if it can work , it may be more suceptible to data loss than solid state media |
Pirate Chronic TriniTuner
Joined: 26 Feb 2008 Tech posts: 596 Location: All bout d place...i probably lost!!! My 2NRide:
Posted: Thu Jul 02, 2009 7:25 pm Post subject: |
yes it could.
IIRC on pioneer's site a while ago for the 6900UB series they demonstrated the USB feature of the deck using an external HDD. |
Posted: Thu Jul 02, 2009 7:31 pm Post subject: |
external solid state drive is no different to a usb stick with larger capabilities
only issue will be if the usb port had enough current to power the drive |
Firewall Chronic TriniTuner
Posted: Thu Jul 02, 2009 8:10 pm Post subject: |
| sometimes the head unit itself limits the capacity which it can read (some can only go up to 16gb, so try it first) |
D_bodyguard Chronic TriniTuner
Joined: 25 Dec 2007 Tech posts: 562 Location: Driving HARD ON the TASKA ROAD / M2 around 6am i nthe morning and 4pm, so clear the road for meh.... My 2NRide: NISSAN y-11
Posted: Thu Jul 02, 2009 9:33 pm Post subject: |
| yes it can but many ppl including meh padna runs up to 40gig (western digital 40 HD) it works but you will need a external casing and a DC to AC supplier to supply the current for the HD cause the deck cannot sustain such a load. Also the HD has to be formatted and not partitioned, and when formatting ...formatt it as a flash drive is and it will work . Had it running on a 690UB. Also for some strange reason only the western digital 40 gig works nothing higher and no other brand. |
carfreak1024 3NE 2NR for life
Joined: 05 Nov 2007 Tech posts: 203 Location: Trinidad, Maracas My 2NRide:
Posted: Thu Jul 02, 2009 9:42 pm Post subject: |
i used a 160gb western digital passport on a pioneer 6000ub, but could not use the extension, i had to connect it directly to the rear of the head unit.
When i used the extension the initial load time was too long. it loaded but took like 10 minuted to load the entire drive full of music, without the extension it was like 2-3 mins. |
SmokeyGTi I LUV THIS PLACE
Joined: 22 May 2006 Tech posts: 935 Location: Trinidad My 2NRide:
Posted: Fri Jul 03, 2009 7:41 am Post subject: |
| SR wrote: | external solid state drive is no different to a usb stick with larger capabilities
was wondering if anyone would notice that
a lot of drives (especially the non-solid state ones) use two usb inputs - one for power, one for data, or they have an external power source |
Posted: Fri Jul 03, 2009 8:30 am Post subject: |
| carfreak1024 wrote: | i used a 160gb western digital passport on a pioneer 6000ub, but could not use the extension, i had to connect it directly to the rear of the head unit.
I also have a WD Passport 160g. but what is the extension? this drive is power by the USB. |
Chiney punchin NOS
Joined: 03 Apr 2005 Tech posts: 3013 Location: Maracas,St.Joseph My 2NRide: Nissan Wingroad
Posted: Fri Jul 03, 2009 8:38 am Post subject: |
^^ he meant USB Extension..
the power decreases across the extension as u increase in LENGTH
invest in a GOOD branded 32GB Flashdrive... and u orn like boil corn! |
Posted: Fri Jul 03, 2009 8:52 am Post subject: |
| Chiney, true, 32 GB of music is a whole lot. you can't done listen to all that. |
Chiney punchin NOS
Posted: Fri Jul 03, 2009 9:11 am Post subject: |
no u cant..  |
(...Rovin...) 3NE 2NR Power Seller
Joined: 21 Jan 2006 Tech posts: 3653 Location: Chaguanas My 2NRide:
Posted: Fri Jul 03, 2009 10:18 am Post subject: |
makes me wonder what ppl doing with 160g ...u will get old & still not listen to all d music that can hold
i like 320kps for my mp3s....  |
Chiney punchin NOS
Posted: Fri Jul 03, 2009 10:30 am Post subject: |
^^ nothing less !  |
Posted: Fri Jul 03, 2009 11:14 am Post subject: |
i did this aready for someone,but we used a solidstate drive from toshiba for it
worked pretty well |
Posted: Fri Jul 03, 2009 1:39 pm Post subject: |
the extension is the usb extender that makes it possible for you to plug in a memory stick and not have it behind the head unit, basically the cord that makes the USB on the back of the head unit longer.
Well when i connected the HDD using just cord that came with the hard drive it worked faster. |
theblitz Chronic TriniTuner
Joined: 24 Jun 2007 Tech posts: 625 Location: South Trinidad My 2NRide: Toyota Corolla
Posted: Fri Jul 03, 2009 1:56 pm Post subject: |
richiepooh, yes some drives or sizes of drives work on some decks. Before you buy the best bet is to try it from a friends drive possibly.
But this:
| Soundstream_626 wrote: | great enough vibrations can damage the platters on hard drives
so even if it can work , it may be more susceptible to data loss than solid state media |
... is serious talk. The read heads can scratch the platters and firetruck up the disk. It is not even advisable to walk around with a laptop that's on far less drive through pot-holes with a non-solid-state drive. |
Chiney punchin NOS
Posted: Fri Jul 03, 2009 4:38 pm Post subject: |
some harddrives come now with sensors to stop the head wen shocks above rating Gs are detected. the harddrive will use its buffer memory in the mean time..
realistically, one cannot mashup a harddrive by driving, once using a disk with the features above eh, but is trinidad road. even though some can, and are made to operate at certain shock levels, with our roads.... i call 32gb flashdrive on this! |
Posted: Fri Jul 03, 2009 4:45 pm Post subject: |
| but I head of those in some IBMs but any drive you would be using sold by WD or otherwise for cheap will not have this feature. And realistically, yes you can damage a drive by driving. |
