mikeae91 Street 2NR
Posted: Wed Jul 01, 2009 9:07 pm Post subject: changing plugs tomorow which ones to buy |
yeah guys wanna do i tune up tomorrow what plugs to buy and price.
4age 20v st
and whats the best way to clean my injectors
whats are the belt #'s |
corollalover101 punchin NOS
Joined: 10 Mar 2006 Tech posts: 3395 Location: Giving the more fortunate a reason to be emotional My 2NRide: Toyota Sprinter Trueno GT Apex
Posted: Wed Jul 01, 2009 9:25 pm Post subject: |
| can go iridium heat range 6 they cost between $240 and $320 depending on where you shop, belts are 5pk 1050 and 5pk850, timing belt is 111 teeth, you doing the injector cleaning yourself? |
mikeae91 Street 2NR
Posted: Wed Jul 01, 2009 9:27 pm Post subject: |
| how u mean take them out or open throttle and sray inside with car cleaner,gumsolve |
Posted: Wed Jul 01, 2009 9:35 pm Post subject: |
| spraying any kind of cleaner into the fully assembled unit would be moot owing to the positioning of the trumpets, better to open the air box ( part labeled 4 throttle) with a hex key, remove the trumpets (10 socket) note the order i.e blacks on the outside brown on the inside, wash the trumpets with soap and water and let dry, wipe the bottom half of the airbox with a cloth and spray some Bars into each ITB while they're closed let it soak, then open them and spray the Bar's in each cleaning out the gunk, also remove the piping that connects the AFM to the airbox and clean it too as it may have some blow-by oil caused by high revs esp if you don't have a catch can or filter on the crankcase breather |
Posted: Wed Jul 01, 2009 9:39 pm Post subject: |
As for the injectors you can have them cleaned by a mech or if you're technically inclined you can remove them, remove the 4 rubber gaskets off them (gently) and then spray and soak the injectors in Bars/ carb cleaner for at least a half hour
if you're cheap or unsure, just dump a bottle of redline in a half tank of premium and go for a highway blowout
Last edited by corollalover101 on Wed Jul 01, 2009 9:40 pm; edited 1 time in total |
TRDcorolla TriniTuner 24-7
Joined: 28 Nov 2007 Tech posts: 1701 Location: living in ah age where a pizza reaches my house b4 the police does My 2NRide: Toyota Celica GTS
dont mean to spam, but this is what the toyota room is for, props to you cl101
carry on |
mikeae91 Street 2NR
Posted: Wed Jul 01, 2009 10:43 pm Post subject: |
| thanks man i think i'll do the highway blowout as i'm unsure about the injector takinh out. as for the thrumpets i already took out mines someone said it wudda make me go faster but i guess it just made me burn more gas i think.... leh me know ok. |
D3monic Trinituner Peong
Joined: 30 Jan 2008 Tech posts: 439 Location: Mt. Lambert My 2NRide:
Posted: Wed Jul 01, 2009 11:36 pm Post subject: |
Good info. i studying to do this weekend........  |
Posted: Thu Jul 02, 2009 5:52 am Post subject: |
mikeae91, now lemme stress here that what I'm about to type is my opinion and is subject to correction by any of the guys more familiar with modding the ST.
In my opinion the removal of the trumpets would not net you any gains, I'm saying this based on the way the trumpets are positioned
 | | Click for full-size. |
it seems that they are curved to allow air entering the box to reach the furthest ITB/Cylinder first and then the subsequent ones from left to right, considering the immense vacuuming force that those throttles have when opened, I'd suspect having no trumpets there would result in the left-most cylinder being starved for air by comparison with the right-most one, increasing the possibility of leaning out cylinder 1 |
toyotajumbie Sweet on this forum
Joined: 27 Apr 2007 Tech posts: 282 Location: I doh know,I doh care,Ah cyar read...... My 2NRide:
Posted: Thu Jul 02, 2009 6:16 am Post subject: |
| mikeae91 wrote: | | thanks man i think i'll do the highway blowout as i'm unsure about the injector takinh out. as for the thrumpets i already took out mines someone said it wudda make me go faster but i guess it just made me burn more gas i think.... leh me know ok. | Now I just enquiring here eh........ If you remove the air intake box on a 20V silver top to expose the trumpets in the hopes of gaining a better flow of air in an attempt to gain more power, what do you connect the Air Flow Sensor to? |
Posted: Thu Jul 02, 2009 7:30 am Post subject: |
| toyotajumbie, I feel he just took the trumpets out the airbox and closed it back |
haydn28 Chronic TriniTuner
Joined: 08 Oct 2008 Tech posts: 669 Location: GTune Performance My 2NRide: Toyota Starlet
Posted: Thu Jul 02, 2009 12:07 pm Post subject: |
to clean injectors , i get a chopped injector harness, and gumsolve.
remove injectors, remove rubber seals, plugin d harness with 2 extending wires to pulse on the battery , make sure u know who is positive and negitive, get someone to spray gumsolve at the top of the injector while u hold down the POSITIVE WHILE U PULSE THE NEGITIVE to simulate an injector pulse ...if the injector clogged u just have to continue sprayin and PULSING till it blows free Usually in around 20 seconds....wipe up and in stall ur seals back and u good.. this method work great for me jus be careful not to damage the meshin in the injector while u sprayin d gumsolve
A172 Riding on 17's
Joined: 11 Aug 2008 Tech posts: 1276 Location: inna lil blue car.... My 2NRide: Chevrolet Monza
Posted: Thu Jul 02, 2009 12:22 pm Post subject: |
| haydn28 wrote: | to clean injectors , i get a chopped injector harness, and gumsolve.
x2
works well IMO |
| haydn28, the 20v injectors are side feed |
Zeriam punchin NOS
Joined: 06 May 2006 Tech posts: 2850 Location: Morvant My 2NRide: Toyota Corolla
Posted: Thu Jul 02, 2009 12:28 pm Post subject: |
 | i do the same as well. 1 additional thing is i soak the injectors for a short while for the dried up bits to get loose. |
Posted: Thu Jul 02, 2009 12:31 pm Post subject: |
Cl101 i know dat i said to spray from the part that goes in to the rail  |
Posted: Thu Jul 02, 2009 12:37 pm Post subject: |
it dont work well when u try to spray BACK up the injector , spray to allow natural injector flow , another method i workin on is to aquire an additional rail use a speare pump to pump gumsolve to the rail with old seals init from a container and pulse the injectors one by one , this shud give ah bess clean as the infectors will be under pressure with gumsolve flowing through it  |
Posted: Thu Jul 02, 2009 1:00 pm Post subject: |
| ^^ that would work well |
Posted: Thu Jul 02, 2009 1:08 pm Post subject: |
also using super will clog ur injectors faster and get coat ur tank with red sheit from its dye soo use it at ur discretion guys, ur 20v were made to run on 100 octane RON gasoline so a management like emanage blue is a good investment to get ur cars running well and make power, as it can trim and add fuel and timing also datalog ur cars sensors so u can actuall SEE and not GUESS what is happening , jus make sure u go by a tuner who knows toyota and tunes dem regularly WITH a GOOD wide band not d mango tree tuners i does be hearing bout,
emanage ultimate $5200 FREE install and road tune  |
Posted: Thu Jul 02, 2009 1:13 pm Post subject: |
| haydn28, how does the emanage circumvent the self-learning ways of the 20V ecu? Which on most piggybacks tends to revert back to factory settings |
