Headlight or harness problem?...SOLVED
Post new topic   Reply to topic   printer-friendly view    trinituner.com Forum Index -> TECH STUFF
Lean Wid IT
Tech posts: 503
My 2NRide: Mitsubishi Evolution X
PostPosted: Wed Jul 01, 2009 7:25 pm
   Post subject: Headlight or harness problem?...SOLVED
what happening my car was by the mechanic some weeks ago to do a conversion and they unharnessed the engine....but was takin too long so i took it back..but in doin so i encountering a problem..
what happened when i got it back and put on the headlights (HId's) it was flickering slightly..but i let it passed then 2 days later it started flashin all over the place the driver side stopped workin eventually so i changed the balast thinkin it was that...and it worked fine for a while
the next day same problem occurred but with the other side so i changed that ballast as well...thinkin that wud have resolved my issues but to no avail
and right now if i put them oon they come on for a while and then the 2 of them come off completely and if i drivin sometimes they flicker like strobes....i dont know what can be causin this is it a HID problem?...or can a part from the harness not be wired properly?...
because it's only in the headlights alone for the HID's i'm gettin this problem
i need help pplz
buzz
Tech posts: 504
My 2NRide: TVR Cerbera
PostPosted: Wed Jul 01, 2009 7:48 pm
humble suggestion
loose/broken wire? Neutral
Lean Wid IT
Tech posts: 503
PostPosted: Wed Jul 01, 2009 8:05 pm
boy well i was thikin it have a short but is where?....
Tech posts: 2484
My 2NRide: Toyota Corolla
PostPosted: Wed Jul 01, 2009 8:38 pm
the bulbs may be going
connect the ballasts directly to the battery and see if they give you the same issue
D_bodyguard
Tech posts: 562
Location: Driving HARD ON the TASKA ROAD / M2 around 6am i nthe morning and 4pm, so clear the road for meh....
My 2NRide: NISSAN y-11
PostPosted: Wed Jul 01, 2009 10:16 pm
try this:
put back the stock bulbs and see if it also happens ......if it happens that means it has something to do with the old original harness
if it not flickering attach the HIDs and run it direct without the old harness (ah switch if you could)
and secondly relly check them bulbs Laughing
View user's profile Send private message Yahoo Messenger
Lean Wid IT
Tech posts: 503
PostPosted: Fri Jul 03, 2009 5:35 am
well i got it sorted it out turned out to be a slack fuse.......thanx for all d help
Hook
Tech posts: 3150
Location: Wondering why that fag is so obsessed with getting access to my facebook.
PostPosted: Fri Jul 03, 2009 11:06 am
lol.....THIS is why I keep telling ppl to start with the simple stuff first!
so now u have two spare ballasts?
glad u got thru tho
cacasplat3
Tech posts: 3170
Location: Where Fuel Is Cheaper Than Bottled Water......
PostPosted: Fri Jul 03, 2009 5:03 pm
a loose fuse once melted the holder in a friend's car.......the dash lights and headlights would give problems now and then..........i took it to an electrician and the cost was about $40 to repair it...............
in a case like this u check the main things as Hook suggested: switch, wires, connectors and fuse..........basic troubleshooting.
Hook
Tech posts: 3150
PostPosted: Fri Jul 03, 2009 11:58 pm
*goes into old man mode*
Man I had a problem once with my high beams not working, but before I tried all kinda ting with the switch or buying a new pair of Silverstars, I took a listen to the relays and found that one wasn't clicking on with I flashed 'em.
Draw for the multimeter and realized that it's getting power, but it's not working. Cool. Changed relay but a week after, same problem pops up again.
Opened up both relays (good thing I didn't get around to emptying that bin in the garage) to find the plastic holding the switch contacts at the end of the coil melted and warped so that it couldn't reach to close the circuit when the coil was activated...both relays. So, time to check the socket.
On closer inspection of the socket, turned out that one of the spade connectors had somehow opened up a bit and the relay pin was just wiggling around in there and sparking, causing excessive heat (there were slight scorch marks on the socket) which caused the relays to malfunction like that.
Couple squeezes of a needle nose pliers later, problem solved, relay pins are nice n' snug in the sockets and the problem has never resurfaced.
The moral of the story: start with the basic stuff first Idea
Lean Wid IT
Tech posts: 503
PostPosted: Sat Jul 04, 2009 2:05 am
glad u got thru tho
yeah thanx..and well yeah i have a whole extra kit cuz i bought a differnt kit..but it's not totally to waste cuz i can use if for myh fogs for d while
THE SYNDICATE
Tech posts: 1804
My 2NRide: Nissan B12 Sentra
PostPosted: Tue Jul 07, 2009 6:58 am
good to hear u got through.
Post new topic   Reply to topic   printer-friendly view    trinituner.com Forum Index -> TECH STUFF All times are GMT - 4 Hours
