TRIPLE ENCLOSURE............ HELP????
Post new topic   Reply to topic   printer-friendly view    trinituner.com Forum Index -> I.C.E.
belt_tightener
Tech posts: 8
My 2NRide: Subaru Legacy Spec. B
PostPosted: Sat Jun 27, 2009 8:25 pm
   Post subject: TRIPLE ENCLOSURE............ HELP????
i need help building an enclosure for three rockford P3's Dual 4 12 inch......any ideas on how it should be built with specs would be greatly appreciated.....thanx
noyztoyz
Tech posts: 382
PostPosted: Sat Jun 27, 2009 9:21 pm
vehicle info and dem kinda ting..
noyztoyz
Tech posts: 382
PostPosted: Sat Jun 27, 2009 9:22 pm
if you dont know much bout car acoustics and tuning and performance and ting, it better to let some1 do dis wuk for yuh, because u may end up wasting a lot of time and money. But we will help the most we could.
southside connections
Tech posts: 1976
PostPosted: Sun Jun 28, 2009 1:22 am
answer these questions-
what car?
what trunk space?
amplifer power?
3stagevtec
Tech posts: 4476
My 2NRide: Suzuki Grand Vitara
PostPosted: Sun Jun 28, 2009 10:56 am
i'd do 6cu.ft net (max) tuned 36-38Hz.. use between 12 - 16sq.in port area per cu.ft..
View user's profile Send private message Visit poster's website
Pre
Tech posts: 104
PostPosted: Sun Jun 28, 2009 9:28 pm
what kind of car is it going in? If its a wagon i have a beastly enclosure tuned bout 25hz specifically designed for subs around that power range if u want to try it out pm me and we can organize something d only ting is since my music get thief out u will have to provide your own vehicle and power since i no longer have any amps in my car and if u have ur subs already better yet.
belt_tightener
Tech posts: 8
PostPosted: Mon Jun 29, 2009 8:25 am
IT is a Panel Van ....so trunk space is not really a problem..lol....and the amplifier is a powerbass asa 3000.....the amplifier equally matches the RMS on the speakers..... just remember it must be for three subs...(rockford Fsgate P3's).....thanx lot guys your efforts are greatly appreciated....
slacker_jack
Tech posts: 1919
My 2NRide: Nissan Almera
PostPosted: Mon Jun 29, 2009 12:46 pm
hoss your amp is the powerbass XA3000d, not asa, there is no asa 3000d.
that amps power is 6000watts max, 3000rms @ 1 ohm.
with 3 rf p3's d4 you might not be able to get the full potential out of that amp (3000rms @ 1 ohm).
the best you can do is you can hook up each one series to get 8 ohm & parrallel them to get a final impendance of 2.6 ohms, you should get a little more than 1500rms at that impendance since the amp puts out 1000rms @ 4 ohm & 2000 @ 2 ohm.
Tech posts: 1976
PostPosted: Mon Jun 29, 2009 12:58 pm
he has the asa 1500.1,prolly mixed it up with the 3000wmax rating
slacker_jack
Tech posts: 1919
PostPosted: Mon Jun 29, 2009 1:22 pm
well is better he use 2 of them & done, that 3 sub configuration will result in him ending up with a final impendance below 1 ohm or above 1 ohm (2.66 as I stated just now). there is no way he will be utilizin the full power of that amp.
if he goes below the 1ohm final load he is risking damaging the amp & if he runs at 2.66 he will not be getting no kind of power (3 of those subs require 1500rms & the amp will be putting out more than a proper 500 at that impendance), his best bet is to wire all of them parallel & get a final impendance of 1 ohm with a power requirement of 1000rms (& both me & you know those rf will handle that 1500 rms comfortable)
Tech posts: 1976
PostPosted: Mon Jun 29, 2009 3:12 pm
or he can have dual 2ohm subs,series each to 4ohm and then parallel to 1.33ohms
belt_tightener
Tech posts: 8
PostPosted: Fri Jul 03, 2009 8:06 pm
Firewall
Tech posts: 597
PostPosted: Fri Jul 03, 2009 11:25 pm
So the speakers are D4.
The vehicle is a panel van.
The amp is 1500rms.
Your FIRST problem:
The subs can either be wired to 2.67:
your amp will put a little less than 750rms at 2.67ohms.
or to an ohmage below 1 ohm
(your amp is not stable at that ohmage i.e your SECOND problem)
With Dual 2ohm speakers you can have:
With 3, you get a 1.33 ohm load
With 4 you get a 1 ohm load:
downside, you will need to change you amp to a 2000.1
HOWEVER:
if you run only 2 D4 speakers (of which you have 3) you can get it down to 1 ohm:
keep your same amp, and sell the other speaker to get some cash for deadening.
the speakers will get 750 rms each (if you believe the amp specs - personally i think around 700rms each) the speakers will take it but NEED to be broken in PROPERLY.
For a box for a panel van, i'd say around 2.2 cubic each tuned to 36-37Hz.
Post new topic   Reply to topic   printer-friendly view    trinituner.com Forum Index -> I.C.E. All times are GMT - 4 Hours
