20v help!!!!
Post new topic   Reply to topic   printer-friendly view    trinituner.com Forum Index -> TOYOTA
firehead..
Tech posts: 155
PostPosted: Fri Jun 26, 2009 3:24 pm
   Post subject: 20v help!!!!
How can i know if my vvt is stuck....sumtimes i can feel the car really pulling, then sumtimes its like it jus dead...
lately im hearin a hissing noise whenever i press the gas and upon start up..and my car is ideling higher than normal..like at 1000rpm...
also i noticed that the vvt solenoid is loose (im able to turn it about 1/4 turn with my hand)..is this normal?...
any help is greatly appreciated...
car:levin
engine: 20v black top
Zeriam
Tech posts: 2850
My 2NRide: Toyota Corolla
PostPosted: Fri Jun 26, 2009 3:31 pm
high idle clean ur iscv and check to see if the thermostat is good. the solenoid shouldnt be able to move so fix that, as for the dead feeling if after u fix those things and it still dead check a mechanic for some pro advice.
firehead..
Tech posts: 155
PostPosted: Fri Jun 26, 2009 3:44 pm
Thermo. is a new one from toyota...i will take out the vvt solenoild an change the o'ring one time since im gonna tamper with it...the high idle started after i cleaned the intake about a week ago....also the car has quieted down quite considerably after the recent oil change...(tappits not as noisey)...
How would i know if the vvt is stuck onn?....ive heard that u usually hear the hissing noise for about a sec. on start up because the vvt activates for that brief moment...
A172
Tech posts: 1276
My 2NRide: Chevrolet Monza
PostPosted: Fri Jun 26, 2009 3:48 pm
   Post subject: Re: 20v help!!!!
must.......resist.. Mad
Laughing
on a serious note, Zeriam seems to be on the ball there, good luck.
firehead..
Tech posts: 155
PostPosted: Fri Jun 26, 2009 3:54 pm
bump..
Hook
Tech posts: 3150
Location: Wondering why that fag is so obsessed with getting access to my facebook.
PostPosted: Fri Jun 26, 2009 5:48 pm
sounds like a vacuum leak...check to ensure that all hoses are in the correct place and that none are cracked/loose/leaky
but it's supposed to idle around 1000rpm when it's really cold (like at start-up early in the morning)
and it wouldn't hurt to clean the ISCV like Zeriam said
this is not normal....it's supposed to have two 10bolts on it..two #5 allen screws can work as well
the only way to know if your oil control valve is stuck is to remove it and apply 12volts to the terminals and check for movement
shinakuma
Tech posts: 359
PostPosted: Fri Jun 26, 2009 11:05 pm
1pat 4 having self control A172 Laughing
firehead..
Tech posts: 155
PostPosted: Sun Jun 28, 2009 10:10 pm
the blots are holding the vvt solenoid in place...im able to turn the unit its self with my hand, not the bracket..i checked it according to the engine manual and it seems good(resistance was to spec. and the solenoid is moving when 12v is applied)....i checked all the vacume lines..they good...im gonna tackel the isc valve this weekend. it tends to only idel higher at night though...sumtimes it will idel normal (@800-850rpm) but once i rev it only drops bk down to 1000rpm...
oh shux!!!..ah wonder if it could be the thermo o'ring?...i now remember i didnt change that....
haydn28
Tech posts: 669
My 2NRide: Toyota Starlet
PostPosted: Sun Jun 28, 2009 10:28 pm
like u 4get men like a172 on d prowl on these forums orr wha? Laughing
Tech posts: 2535
My 2NRide: NISSAN SENTRA b14
PostPosted: Mon Jun 29, 2009 10:20 am
wha oil u using there boy?
u got tru with the distributor thing?
u gettin called out wednesday so make sure u working good!!
Hook
Tech posts: 3150
PostPosted: Mon Jun 29, 2009 10:55 am
could be both the ISCV and the throttles sticking...it wouldn't burt to spray the throttle close springs one time and spray some lithium grease to lube 'em
about the OCV moving, it's prolly just to tighten it down properly, but even if it's a bit loose, once the o-ring sealing properly, u won't leak any oil through it
firehead..
Tech posts: 155
PostPosted: Thu Jul 02, 2009 10:59 pm
usin amsoil 10w-30 rite now an luvin it..it nuh bunnin off fast like the mobil 10w-30...car revin up smoother now to and tappits not as noisey...
Hook, bro, ah goin an tackel dem ting in d mornin...i still in wok...
X_Factor, ah see yuh call thismornin....i was sleepin real strong...and yeah ah get tru with the distributer thing...
honda hoe
Tech posts: 6030
My 2NRide: Honda Integra Type R
PostPosted: Thu Jul 02, 2009 11:48 pm
Laughing Laughing
Post new topic   Reply to topic   printer-friendly view    trinituner.com Forum Index -> TOYOTA All times are GMT - 4 Hours
