Rahtid Sweet on this forum
Joined: 08 Jul 2005 Tech posts: 351 Location: Inna De Hyatt My 2NRide:
Posted: Fri Jun 26, 2009 11:55 am Post subject: My compressor not coming off |
D15b civic engine,compressor not turning off,electrician said it has to be disconnected from the brain,and switched otherwise,
any body knows about this? |
slow323 Trinituner Peong
Joined: 18 May 2005 Tech posts: 437 Location: pos, maraval My 2NRide:
Posted: Fri Jun 26, 2009 1:26 pm Post subject: |
| do a search this problem was here b4 i think it had to do with a electrical part goin bad cah remember the name off hand |
IMPREZZING 3NE 2NR for life
Joined: 27 Jun 2006 Tech posts: 153 Location: Being the devil's advocate My 2NRide: Subaru Impreza WRX STi
Posted: Fri Jun 26, 2009 1:32 pm Post subject: |
| pressure switch? |
Hook punchin NOS
Joined: 18 Jan 2004 Tech posts: 3150 Location: Wondering why that fag is so obsessed with getting access to my facebook. My 2NRide:
Posted: Fri Jun 26, 2009 2:08 pm Post subject: |
nawww. pressure switch senses the gas pressure in the system and allows it to switch on provided there's enough gas in there for operation
Rahtid, when u say it not switching off, do u mean it's not cycling on and off during normal operation? (which would appear to be a/c thermostat related)
or do u mean even when the switch is off, step-up and fan comes off but the compressor is still on and the engine boggs down? |
slimshiney 3NE 2NR for life
Posted: Fri Jun 26, 2009 4:56 pm Post subject: |
| isn't the thermostat (not the engine cooling one) responsible for the cycling of the compressor.....get it checked.... when compressors are not cycling properly they damage quickly......listen to the rev and even take a lil peek by the compressor..confirm if it's really not coming off...., |
Posted: Fri Jun 26, 2009 5:02 pm Post subject: |
| Hook wrote: | nawww. pressure switch senses the gas pressure in the system and allows it to switch on provided there's enough gas in there for operation
yes,,the green light on the switch is on in the car,ac fan and compressor stays on once car is on,if u turn the knob for ac,,it comes out white like mist,really cold too,but if off,,and drivin,it boggs down the engine,burnin rel gas too eh,,,btw,,i gassed up a while ago |
Hook punchin NOS
Posted: Fri Jun 26, 2009 5:13 pm Post subject: |
wow....something controlling the switch-off for the compressor has gone terribly awry!
seek a proper electrician who won't try to dig up in the ECU...the a/c pin on teh ECU simply indicates that there's a/c load on teh engine for the ECU to adjust for the extra load...has nothing to do with switching anything...a/c control is a separate control unit
I suspect it has something to do with the A/C control unit (it controls blower speed, condensor fan speed, thermostat switching/compressor cycling etc.) or it's possibly the compressor relay sticking with the contacts closed (seen this happen due to loose relay terminal on headlight relays heating up and moving to make permanent contact inside the relay)
I been told by an a/c tech years ago that if u don't cycle the compressor on and off, the oil gets very cold and thick and sometimes tends to crystallize and can ruin the compressor....sort this out quick before it costs u a compressor change and a re-gassing |
Posted: Fri Jun 26, 2009 5:35 pm Post subject: |
| ok,,maybe tomorrow ill chk one |
manualmx Riding on 13's
Posted: Fri Jun 26, 2009 6:39 pm Post subject: |
| Yur compressor clutch is stuck in the closed position. Could be due to faulty rubber isolators on the unit. Will need to remove compressor and repair or replace. |
D_bodyguard Chronic TriniTuner
Joined: 25 Dec 2007 Tech posts: 562 Location: Driving HARD ON the TASKA ROAD / M2 around 6am i nthe morning and 4pm, so clear the road for meh.... My 2NRide: NISSAN y-11
Posted: Fri Jun 26, 2009 8:17 pm Post subject: |
hoss if yh going and change it take ha piece ah wood,rest it on the base ah the compressor and give him ah good few shots with ah big hammer lol.....it might work lol....i saw ah man do this on his b13 and i thought like the man madd but when he crack it ah few time the damm thing start to work one time ....  |
Posted: Sat Jun 27, 2009 7:41 pm Post subject: |
D_bodyguard,can i do it while it on d car???
manualmx,,,i just undid the jacks,,so its off,but when i plug back the jack,,the fan comin on,as well as compressor,,,
i go jus run witout ac for d while,,,i eh find a place where sellin compressors,,,i sold two this yr already eh,i shud have kept them as my mech told me  |
