NY4PD Street 2NR
Joined: 05 Aug 2008 Tech posts: 40 Location: Florida My 2NRide: Honda Civic Si
Posted: Thu Jun 25, 2009 8:03 pm Post subject: SwayBar Adjustable Linkage Mods. |
Hi,
This is a modification for the Blox Adjustable Swaybar Linkage for anyone wanting to use this on there car.
When using these swaybar linkage you will have to make yourself spacers for them to fit right between the Lower control arms and the swaybar. The spacer between the liknage and the swaybar is using a 7/8" steel hollow spacer and the spacer between the lower control arm and linkage is using 5/8" steel hollow spacer, this helps keeps the swaybar link in the right position. You will see in the photos i have added all new Energy Suspension bushings onto the Rear Trailing Arms and also upgraded to Adjustable rear Toe Arms and rear Adjustable camber kit and Swaybar bushings with the Tie Bar added to match the Lower control arms. Hope this was a helpfull tip for guy's wanting to use Adjustable Swaybar linkage. enjoy.
Ps: I forgot to mention that I have use heat shrink over the steel spacers to make it look fairly good under the car.
 | | Click for full-size. |
 | | Click for full-size. | [/img] |
Hirotoshi Riding on 13's
Posted: Fri Jun 26, 2009 2:00 pm Post subject: |
try and place those jack stands further apart, for more stabillity and your safety  |
NY4PD Street 2NR
Posted: Fri Jun 26, 2009 3:43 pm Post subject: |
| Hirotoshi wrote: | try and place those jack stands further apart, for more stabillity and your safety  |
Thanks for the good tip there, I had other stands also but was remove because the car is finish and was in the process of taking it down then decide to take pictures first. The car is driving on the road right now and feels great...
Thanks for the tip anyway. |
phaze Ricer
My 2NRide: Honda Civic SiR
Posted: Fri Jun 26, 2009 10:04 pm Post subject: |
| nice brian... glad yuh finally put up in the bushings... they lookin gd, nice sway bars too... |
NY4PD Street 2NR
Posted: Sat Jun 27, 2009 8:17 am Post subject: |
| phaze wrote: | | nice brian... glad yuh finally put up in the bushings... they lookin gd, nice sway bars too... |
Thanks for the comments, I took a while but its done now, The car rides like new with no noise and handles really good, around corners she's like glued to the road. The ride is very smooth and comfortable no bounce at all and with the adjustable sway bar links the car dont lean to one side when turning corners, The suspension was tune and balanced out when alighnment was done. all the parts under the car is all adjustable for tunning and ride comfort. |
ingalook Sweet on this forum
Joined: 11 Apr 2006 Tech posts: 261 Location: Pakaskas My 2NRide:
Posted: Sat Jun 27, 2009 10:08 pm Post subject: |
| What shock/spring combo you using dude? |
NY4PD Street 2NR
Posted: Sun Jun 28, 2009 7:39 am Post subject: |
| ingalook wrote: | | What shock/spring combo you using dude? |
KYB's struts and Megan springs, rides really good almost like a new car. as for handling its like much better than my skunk2 springs and Koni struts combo. around corners islike glue onto the road and for lunching in drag racing on the trac is really good, not much lift of the front and the rear don't really dip to much, which is good for launching. The main thing is the wife don't complain like she did in the past when I had the Koni struts with the skunk2 springs combo, she taught she was in a new car...lol.... |
