evo-STI-k Chronic TriniTuner
Joined: 10 Nov 2003 Tech posts: 528 Location: The Ghetto San Juan My 2NRide:
Posted: Tue Jun 23, 2009 9:14 am Post subject: |
| SR wrote: | presently buildign a new system for one of the rooms in the house
DLS Ms6a components
Mono sub amp from parts express
DLS 12" sub
using car audio speakers as they will be able to handle harsher environments than the home audio stuff as the room is like a porch area as well
havent decided on the amp as yet
presently i have 2 channel sony integrated amp
total cost for the entire system should be under 10k
will post pics of this build up when we start |
there goes the quiet neighbourhood!  |
(...Rovin...) 3NE 2NR Power Seller
Joined: 21 Jan 2006 Tech posts: 3651 Location: Chaguanas My 2NRide:
Posted: Tue Jun 23, 2009 9:25 am Post subject: |
y we trinis always putting house speakers in cars & vice versa ....  |
3stagevtec punchin NOS
Joined: 12 Jul 2006 Tech posts: 4476 Location: killing two stones with one bird... My 2NRide: Suzuki Grand Vitara
Posted: Tue Jun 23, 2009 9:52 am Post subject: |
| (...Rovin...) wrote: | y we trinis always putting house speakers in cars & vice versa ....  |
we just creative.. |
silent_riot Riding on 17's
Joined: 26 Dec 2004 Tech posts: 1345 Location: Gone digital My 2NRide:
Posted: Tue Jun 23, 2009 10:09 am Post subject: |
If you're into building your own stuff, try DIY, its much cheaper and you'll learn a lot especially in enclosure building.
My current hi fi DIY project (small room):
Seas W15Ly001 Midranges
Peerless HDS Tweeters
Custom Passive Xover
Currently redoing those bookshelf enclosures
Marantz CD player
I have a Pioneer integrated amp, but looking into a little better integrated...hard to find the ones I'm interested in trinidad tho.
OAudio Bash 500W sub amp
Image Dynamics 12" sub SEALED...looking to upgrade to something else later on.
Just finishing up the aesthetics on that enclosure as well.
Also doing a DIY 5.1 project (for larger rooms) next month with some other stuff.
On the cheaper side of things, there are headphones..a great reference for personal listening except for visceral bass and lifelike sound stages.
I use the Grado SR60 daily at home...the best value I have ever come across in audio of any form.
A very cheap but good headphone is the Koss KSC75. Lots of bass from a compact headphone.
Also have a Sennheiser HD650 run off an Antique sound lab OTL tube headphone amp...The best midrange and highs I could ever hope for...but I don't use it.
Later on in the year, gonna start experimenting with high efficiency setups for larger rooms. |
| well, i prefer to stick to home theatre speakers for home theatre, they are usually a perfect match for a/v receivers, ie- both impedance and power............ |
Posted: Tue Jun 23, 2009 1:09 pm Post subject: |
cant comment on others
but for my setup the ms6a's came out of my own car whe i upgraded
DLS makes very good home speaker systems and the car audio line is designed around the developments made for the home audio
car audio speakers are usually designed to handle greater fluctuations in temperatures and humidty etc as opposed to home audio where these things are usually more stable
DLS MS6a car audio $1575 a pair
http://www.dls.se/en/car/prod.html?produkt=en_70
Tweeter UP1C, 28 mm (1,1") silk dome tweeter
Woofer size 16,5 cm (6,5")
Power handling capacity 100 W RMS / 160 W max
Frequency range 45 - 20.000 Hz
Crossover point (Hz) 4500 Hz
Sensitivity 92 dB (1W/1m)
Outer diameter of woofer 165 mm (6,5")
Magnet size 100 mm (3,94")
Mounting depth 67 mm ( 2,64")
Crossover Filter box with 6/12 dB slope (LP/HP)
Size of filter box 145 x 85 x 45 mm ( 5,71 x 3,35 x 1,77")
Mounting hole 140 mm (5,5")
Impedance 4 ohm
DLS M60 home audio over 4k a pair
http://www.dls.se/en/home/prod.html?produkt=en_683
Description / type 2-way bass reflex
Finish / colour Black piano
Woofer size 6,5"
Impedance 4 ohm
Frequency range 48 Hz - 30 kHz (-3 dB)
Tweeter 28 mm soft dome tweeter
Sensitivity 88 dB/1m, 1W
Crossover point (Hz) 3600 Hz
Crossover 1st / 2nd order Bessel
Recommended amplifier 50 - 150 Watt
Weight 12,2 kg / 26,9 lbs
Dimension (W x D x H) 200 x 360 x 410 mm (7,9" x 14,2" x 16,1")
so i am sure i can achiev similar performance by building my own enclosures |
nareshseep Chronic TriniTuner
Joined: 29 Jun 2007 Tech posts: 632 Location: down town My 2NRide: Mazda Familia Hatch
Posted: Tue Jun 23, 2009 1:34 pm Post subject: |
| silent_riot wrote: | If you're into building your own stuff, try DIY, its much cheaper and you'll learn a lot especially in enclosure building.
Marantz CD player
Is it possible for me to get a demo of the system? |
DJ Q Shifting into 6th
Joined: 21 Feb 2007 Tech posts: 2169 Location: 137.9 dB My 2NRide:
Posted: Tue Jun 23, 2009 1:41 pm Post subject: |
cheaper to get loud with car subs
cheaper to get loud with DJ mids |
Posted: Tue Jun 23, 2009 2:48 pm Post subject: |
| nareshseep, the plan is after the build to demo it for the ice club at a test and tune event. However, the system was designed for small room listening, which may be hard to get...but I'm trying... |
Posted: Tue Jun 23, 2009 3:22 pm Post subject: |
well i didnt mean u in particular SR, i meant some guys who dont have a clue of either car or house audio knowledge just throwing a bunch of mismatched, unplanned or unresearched items together to make up "a set" & just making a set of ole noise in d place ....  |
crazybalhead punchin NOS
Posted: Fri Jun 26, 2009 12:59 pm Post subject: |
| I also have a HT sub built with a plate amp and a hollywood excursion sub. It's no extreme power, but it is clean and goes pretty low for a damn cheap set-up. |
ruffneck_12 3NE 2NR for life
Joined: 04 May 2008 Tech posts: 221 Location: here My 2NRide:
Posted: Fri Jul 03, 2009 10:58 pm Post subject: |
| wa bout using fiber optics instead of normal RCAs, any change in quality? |
ru$$ell I LUV THIS PLACE
Joined: 04 Aug 2003 Tech posts: 1007 Location: westside My 2NRide:
Posted: Tue Aug 11, 2009 10:49 pm Post subject: |
sorry for bumping this old thread,but looking for a pair of Sennheiser headphones,anyone know where sell them locallly?
btw,if you guys wanna see some professional HT Systems,check out Blu Ray Forum: http://www.blu-ray.com/community/
My HT is in there somewhere,i'll try and find it  |
Posted: Tue Aug 11, 2009 11:19 pm Post subject: |
| pm kaiger on the forum for Senn phones. |
Posted: Sun Nov 08, 2009 6:43 pm Post subject: |
| silent riot any progress and pics? |
slacker_jack Shifting into 6th
My 2NRide: Nissan Almera
Posted: Sun Nov 08, 2009 10:58 pm Post subject: |
ru$$ell, is that a bed in your living room or a cough in your bedroom there?  |
SmokeyGTi I LUV THIS PLACE
Joined: 22 May 2006 Tech posts: 935 Location: Trinidad My 2NRide:
Posted: Mon Nov 09, 2009 8:38 am Post subject: |
have a plate amp 500wrs @ 4 ohms and a type-r 15" dual 2ohms sum also brand new (everything still in box) if you're interested.
i don't think you'll want more for bass than that! |
Posted: Mon Nov 09, 2009 8:41 am Post subject: |
SmokeyGTi.....yo momma!
you wait till I order 1 & then give word that you selling yours  |
Posted: Mon Nov 09, 2009 4:51 pm Post subject: |
^actually its a futon,and its neither my room or the living room,its a dedicated Home Theater Room  |
