mikeae91 Street 2NR
Posted: Sat Jul 04, 2009 11:42 pm Post subject: |
100 what super or premium
i'm not sure whats the problem i cleaned throttle change oil and plugs injectors same probs
what about if my oxygen sensor bad plus the car idles like 1300 ever since the engine was transplanted it never idles correct.
whats the cost of a oxygen sensor for it |
Terran punchin NOS
Joined: 18 Apr 2003 Tech posts: 2749 Location: Sweet Trinidad My 2NRide:
Posted: Sun Jul 05, 2009 3:16 pm Post subject: |
Read my posts... I use premium only.
I know you've posted a few threads about your maintenance issues, so I honestly can't think of what is causing such excessive gas consumption. The high idle is a factor. That is way too high. My engine idles at 800rpm. |
defkerron Riding on 13's
Posted: Mon Jul 06, 2009 7:23 am Post subject: |
| mikeae91 wrote: | grand bazzar and home which is chaguanas and then endeavour then back home might have to go freeport i do alot of small in the area runs,.. but i still think it burns alot..
defkerron thaz real bess mileage u getting 400 -450 piarco to pos and back i think if i have to make that same run it would cost me alot more that you.. |
thas real small running boy, you better do a diagnostic to determine the problem. it will cost you less to find the problem than keep spending so much money on gas.
yeah boy Terran, i got the sport flywheel so i do alot of cruising especially on the highway.
Of course the nice thing about the 20v is the fact that it adapts to how u drive, so if i wanna take it easy like keep it around 3000-3500rpm between shifts you wouldnt believe how little gas it consumes. and well the other way around when i running hard betwen 5000-6000+ it will burn some more but not very very significant.
The Shaffeur oil real good though, was using Royal Purple and Mobil but this oil working real tops.
but you know, you can actually get more mileage using normal NGK plugs rather than the Iridiums i am using....with a small sacrifice in performance. |
dmitc Chronic TriniTuner
Joined: 19 Dec 2007 Tech posts: 506 Location: Barataria My 2NRide: Toyota Corolla
Posted: Mon Jul 06, 2009 9:00 am Post subject: |
Just got 330KM on full tank of super (40 ltrs) $108.
Which is about 40km more than i am accustom getting (i put it down to new PCV valve)
I don't understand why some men gettting 400~450Km on a tank.
I know that you suppose to get better gas milage with a manual as oppose to an auto which is what i have but 100+km that is rediculous unless the size of there tank significantly bigger.
defkerron, how big a tank you have? |
mikeae91 Street 2NR
Posted: Mon Jul 06, 2009 9:46 am Post subject: |
| 330 i think i need to get my odometer working |
Posted: Mon Jul 06, 2009 2:35 pm Post subject: |
yeah boy my tank is a 50L one so it will hold around $130 of super.
my idle is around 930rpm.
i have never run it down to under quarter tank, and usually then it has around 360-380 or so on the tank mileage. It has been so ever since i got it around a year and a half ago. |
Posted: Mon Jul 06, 2009 4:04 pm Post subject: |
defkerron, that's more like it on a 50l tank mines should do ~415km.
I can live with that. |
Terran punchin NOS
Posted: Wed Jul 08, 2009 5:11 am Post subject: |
Yuh see, all yuh men using super. I using premium. I'm not going back to super. When I tried that, I thought my engine was going to die and I've had enough car issues in the past.
If you guys were using premium, and assuming you'd get the same mileage as you would with super, then fordmitc, your 330km would cost you $160 - like what I am currently experiencing.
And defkerron would probably pay closer to $190 to refill his tank.
Still, these kinda figures are below what I expected to get out of a 20V. |
Posted: Wed Jul 08, 2009 10:10 am Post subject: |
| Terran, It hurts my heart to use super but it hurting my wallet more to put premium. Define difference in performance, but right now as long as the engine not knocking i willing to run the super well as least till i get another job |
mikeae91 Street 2NR
Posted: Wed Jul 08, 2009 6:27 pm Post subject: |
| i understan what terran saying super has the car feeling dead and to me the car sounds rough with premium u get power and car runs smoother and quieter |
Terran punchin NOS
Posted: Wed Jul 08, 2009 9:56 pm Post subject: |
dmitc, when I switched to super after the price increase of premium gas, the car actually responded better and fuel economy improved significantly.
After about 3 or 4 refills, everything went downhill. The performance sucked terribly. Instead of cruising at 160km, the car maxed out at that speed and strained to get there. The tach would not swing to 8200 rpm as it normally would, and would crawl to 7000 rpm maximum. Fumes galore. When I kicked down, instead of getting 3 downshifts, just one, and VVT was hardly felt.
Not to mention the knock. I could swear there was a live steelband in my engine bay. It happened all within 1 tank of gas - everything went down.
I switched back to premium and by performance gradually restored itself by about the 3rd refill of premium. I always got knock with premium, and I still get some, but with the super... man, I got really scared.
So, I sucked it up to pay $4 per litre of premium and have never looked back. I try to be more efficient in my driving and not stomp on the gas unnecessarily. But it doesn't take away from the fact that the engine simply burns more gas than it is rated to do, and I believe a lot of that has to do with the quality of gas we get in Trinidad. |
Posted: Fri Jul 10, 2009 6:52 am Post subject: |
| Terran wrote: |
my VVT comes on as normal but does not seem as potent as it originally did,
i catch my ass to reach up to 180km i would accelerate good till about 160 then crawl to reach up the next 20.
No fumes though and rpm range is the same just does not reach up as fast.
All in all i won't recommend super for my engine but money funny these days |
rolling_hard Sweet on this forum
Joined: 01 May 2007 Tech posts: 300 Location: right dey My 2NRide: Toyota Corolla
Posted: Sat Jul 11, 2009 1:58 pm Post subject: |
im running a 20v st auto i just got 396km on a full tank, well it reach 1/4 now. it took me $100 to full up from 1/4, and i does run my car eh.
how them figures looking? |
corollalover101 punchin NOS
Joined: 10 Mar 2006 Tech posts: 3395 Location: Giving the more fortunate a reason to be emotional My 2NRide: Toyota Sprinter Trueno GT Apex
Posted: Sat Jul 11, 2009 2:28 pm Post subject: |
| rolling_hard, you using super or premium? |
Posted: Sat Jul 11, 2009 5:09 pm Post subject: |
| oh my bad.........super |
Raaan Riding on 13's
Posted: Wed Jul 15, 2009 12:41 pm Post subject: |
I run a PCL Altis - 5mts. old. I currently get on average 450km per tank of gas (premium) with a prestone fuel treatment. Most of my driving is at peak traffic hours during the week. On a few ocassions I filled up on the weekend doing more highway running and I got 515km to my tank of gas.
The Prestone gas treatment (red bottle) actually gives me around 40km-50km more on atank of gas.
I used super a few times and noticed performace gradually decreased.
I was saving about $65.00 per tank.
Then I tried using the Prestone Octane Boost ($30) and performance got better.
Pull off was better and the kick down was more agressive.
Savings went down to $35.00 per tank.
To me this is a good option for those who really need to save some $.
But for optimum performance reliability and peace of mind nothing beats premium.
I chose to use the premium and car runs excellent. |
Posted: Wed Jul 15, 2009 12:44 pm Post subject: |
thirsty Riding on 13's
Posted: Mon Aug 24, 2009 4:18 pm Post subject: |
| 20v doh burn gas jed but once you running high revs youll drink!!! |
josh.dookie 3NE 2NR for life
Joined: 19 Sep 2007 Tech posts: 121 Location: in front of that SiR civic... My 2NRide:
Posted: Fri Aug 28, 2009 9:09 am Post subject: |
| i have ae 91 jus like yours.. work lime etc $100 to $120.. 2 1/2 " free flow st as well.. U does change every gear higher than 7000rpm or wat? |
Posted: Fri Aug 28, 2009 9:10 am Post subject: |
| altis man.. real info jed... but is d thread says 20v men lolz.. but its all good jed! |
