spam 3NE2NR is my LIFE
Posted: Wed Jun 17, 2009 10:07 am Post subject: CURRENT ISSUES PLEASE ADVISE |
now my system consist of 5 amps
bass is about 320amps
and mids is 180amps
i have 2 110 alternators
and 5 kinetik 12/16 volt batteries
wit the car off my voltage is about 12.5 and wit it on it is about 13.8
when my bass hits it goes from 13.8 straight down to between 11.8 - 12.3
also the allternator starts spinning slower as if all the current is being
sucked out
is there a way i can atleast keep the voltage out of the 11 range?
would more batteries help? would bigger alternators help?
no i have not done BIG 3 yet **casper stickin**
3stagevtec punchin NOS
Joined: 12 Jul 2006 Tech posts: 4476 Location: killing two stones with one bird... My 2NRide: Suzuki Grand Vitara
Posted: Wed Jun 17, 2009 11:30 am Post subject: Re: CURRENT ISSUES PLEASE ADVISE |
| spam wrote: | wit the car off my voltage is about 12.5 and wit it on it is about 13.8
sucked out |
what rpm does your engine be turning at for the voltage to drop to 11.8 - 12.3V?? usually at least 1600rpm would be required for those alts to start producing some decent power.. |
Posted: Wed Jun 17, 2009 12:06 pm Post subject: |
i know it is over 1rpm but not sure if it is up to 1.6
it is normal cefiero alternators
so a higher rpm should help the voltage?
Posted: Wed Jun 17, 2009 12:28 pm Post subject: |
| you will get quite alot more output at 2000 engine rpm vs 1000 engine rpm.. i'd suggest idling your engine higher while playing.. try between 1500 - 2000rpm while playing all out.. |
Posted: Wed Jun 17, 2009 12:48 pm Post subject: |
ok i will check that today and see what happens
(...Rovin...) 3NE 2NR Power Seller
Joined: 21 Jan 2006 Tech posts: 3651 Location: Chaguanas My 2NRide:
Posted: Wed Jun 17, 2009 12:49 pm Post subject: |
will cost u some gas $ to do be playing at a higher engine rpm
might be better to invest in a nice 350A HO alt from 1 of those companies in d usa (might cost around us$500-600) so u will be getting d full output from ur amps & wont have any more current problems especially for long gallery playing ... |
DJ Q Shifting into 6th
Joined: 21 Feb 2007 Tech posts: 2169 Location: 137.9 dB My 2NRide:
Posted: Wed Jun 17, 2009 1:33 pm Post subject: |
| ^but usually you can't do highway driving with those |
basshead Ricer
Posted: Wed Jun 17, 2009 3:07 pm Post subject: |
this tuner noyztoyz
will be stock soon
300 amp alternator made for use in daily driver vehicles, 300amps at only 2000rpm, not no 5000rpm+ like other brands. You could race to 6000rpm on the highway and it wont damage it. Comes with external voltage regulator for 13-20volts so you could turn it up when is time to crank and lower it down when yuh resting, also can be used on a 16v battery bank.
Best deal on a alternator you can get. Is universal fit so you will have to get a small bracket made, i took 30 mins to make mine, one a dis 300amp alternator in use in a daily vehicle is on demo in my vehicle.
Put the best, the extra money you spend on this will save u money on your battery bank. U will also get a guarantee against failure.
Brand - Excessive amperage |
fuzz_174 I LUV THIS PLACE
Joined: 13 Jun 2003 Tech posts: 1040 Location: Eastern Afghanistan My 2NRide: Ford Capri
Posted: Wed Jun 17, 2009 3:35 pm Post subject: |
What price u paid? |
noyztoyz 3NE 2NR Power Seller
Joined: 21 Jun 2007 Tech posts: 382 Location: all over My 2NRide:
Posted: Wed Jun 17, 2009 7:19 pm Post subject: |
| basshead wrote: | this tuner noyztoyz
will be stock soon
is tru, yall could come check me when my sytem all hooked up and see how it keeps up voltage and i does drive it all day long.
The newer alts out of the states rated 300 amps are built for this purpose.
I sell them with external regulators, so when you hit the highway, turn your voltage down to 13.0 and drive how hard you want..
Mine is there almost 1 month now.. |
Posted: Wed Jun 17, 2009 7:20 pm Post subject: |
| spam wrote: | i know it is over 1rpm but not sure if it is up to 1.6
sit down and rev your car to 3000 rpm then crank your music and see how much higher your current sits at.
Then you would know if u need more alternators. |
kurpal_v2 Riding on 16's
Joined: 28 Dec 2007 Tech posts: 1146 Location: shaking down my bhaji tin My 2NRide:
Posted: Wed Jun 17, 2009 7:32 pm Post subject: |
| 2000rpm safer bro^^^ |
riadb 3NE 2NR Power Seller
Joined: 10 Mar 2006 Tech posts: 2251 Location: Freeport, Trinidad My 2NRide: Nissan P12 Primera
Posted: Wed Jun 17, 2009 10:07 pm Post subject: Re: CURRENT ISSUES PLEASE ADVISE |
| spam wrote: | now my system consist of 5 amps
and mids is 180amps
sucked out
ALLL DAT CURRENT DRAW AND U EH DO A BIG 3 AS YET!!!!!
and yes....i am shouting!!!
stop stickin na dred....daz de 1st thing you shoulda do!!!
if dat doh help i would go with Rovin's idea and buy a good HO alternator with a daily driving rotor and external voltage regulator so u could make highway runs with it.
btw can you charge a 12/16V dual pole battery with 13.8V???? |
Posted: Wed Jun 17, 2009 10:59 pm Post subject: |
well at higher rpm the voltage sittin nice and not reachin the 11 range
Posted: Wed Jun 17, 2009 11:19 pm Post subject: |
good now you know that rpms are the problem. but what voltage did it settle at now?
D your big 3 first and thec come for more solutions  |
Posted: Thu Jun 18, 2009 5:41 am Post subject: |
wit misic loud it droppin to like 12.3-12.6
Posted: Thu Jun 18, 2009 8:41 am Post subject: |
| that's ok -ish |
Chiney punchin NOS
Joined: 03 Apr 2005 Tech posts: 3013 Location: Maracas,St.Joseph My 2NRide: Nissan Wingroad
Posted: Thu Jun 18, 2009 9:04 am Post subject: |
more than ok-ish
for the current draw he speaks of, and know how gallery men is lash out their systems.. hes pretty ok not goin below 12v.
u did the big 3 yet? |
Lance TriniTuner WHOoRE
Joined: 21 Jun 2005 Tech posts: 1380 Location: Arima My 2NRide:
Posted: Thu Jun 18, 2009 10:47 am Post subject: |
My question is how are you currently charging the batteries?
I not too familiar with the 12/16V batteries,
But i am guessing you need to charge the batteries as you would any 16V battery (optimally 18V), and the battery would then output a 12V through its 3rd pole is needed.
So are you currently charging 16V batteries with a 12/14.4V alternator? |
theblitz Chronic TriniTuner
Joined: 24 Jun 2007 Tech posts: 624 Location: South Trinidad My 2NRide: Toyota Corolla
Posted: Thu Jun 18, 2009 1:17 pm Post subject: |
| I just now saw this thread and the big 3 shud have NOT been neglected and what Lance said. From the alternators he's using I'm assuming he's charging at ~13.8V |
