DJ Q Shifting into 6th
Joined: 21 Feb 2007 Tech posts: 2169 Location: 137.9 dB My 2NRide:
Posted: Wed Jun 17, 2009 8:09 am Post subject: |
| bushwakka wrote: | | Supra GT-FOUR wrote: | | anybody know what pressure 215/35/18 tryes should be at? |
with such low profile tyres, u shud run about 34+ i wud say
for de corolla man, i normall run 32 (front) and 30 back |
i have 225/45/17
i run 30 all round...
should i go up to 34 as well?? |
silver racer 3NE 2NR for life
My 2NRide: Mitsubishi Lancer
Posted: Wed Jun 17, 2009 6:05 pm Post subject: |
| i runnin 17's as well, i usually put 35 all around, +2yrs no probs so far.. |
Posted: Thu Jun 18, 2009 8:37 am Post subject: |
| will try 35 and see thanks |
vans 3NE 2NR for life
Joined: 23 Nov 2006 Tech posts: 151 Location: where ever d $ is My 2NRide: Mitsubishi Galant VRG
Posted: Sun Jun 21, 2009 9:30 pm Post subject: |
| what about 38 or 40 psi what probs could that cause |
neckto Chronic TriniTuner
Joined: 07 Jul 2003 Tech posts: 582 Location: Engine Room My 2NRide: Mitsubishi Lancer
Posted: Mon Jun 22, 2009 10:57 am Post subject: |
try it and tell we  |
Posted: Mon Jun 22, 2009 12:18 pm Post subject: |
| i asking cause i curious |
wagonrunner punchin NOS
Joined: 18 May 2004 Tech posts: 3625 Location: where the only valid opinion is theirs ....... :| My 2NRide: Nissan Y10 Wingroad LE
Posted: Mon Jun 22, 2009 12:58 pm Post subject: |
| vans wrote: | | i asking cause i curious |
we can't tell you because your preferences, driving habits, and even route would not be ours.
which is why
| Quote: | try it and tell we  | is the right response.  |
Posted: Mon Jun 22, 2009 1:09 pm Post subject: |
| wagonrunner wrote: | | vans wrote: | | i asking cause i curious |
which is why
which driving habits would require higher/lower pressure? |
insane37 Street 2NR
Posted: Mon Jun 22, 2009 2:27 pm Post subject: |
| can over pressure damage the suspension? |
Posted: Mon Jun 22, 2009 2:30 pm Post subject: |
i enjoy spirited driving and have a lot of rubber between rim and road.
At 32psi, I can enjoy a spirited run from princes town to mayaro,, i feel every single ridge, and know exactly where my tires are placed, and expect suitable traction.
another driver of the car cruises mainly, finds 32psi is too high, and prefers to roll, or stop when rough patches are encountered. they drive the same car at 28psi, and are happy with that.
DJ Q,
does that shed some light on the subject? |
Posted: Tue Jun 23, 2009 8:22 am Post subject: |
oh... so maybe I should experiment with different tire pressures and see which one i'm comfortable with?
is there a recommended range to stay between? |
Posted: Tue Jun 23, 2009 8:43 am Post subject: |
the range we use for light passenger vehicles is 26 - 35
heavier vehicles 30-40 |
skylineGTR55036018 Ricer
Joined: 25 Jun 2008 Tech posts: 21 Location: In The Bo0sted Lane My 2NRide: honda coupe si.
Posted: Tue Jun 23, 2009 10:34 am Post subject: |
| 28 is a gud figure i use dat all the time..and i have no complaints |
Posted: Tue Jun 23, 2009 10:39 am Post subject: |
| each tyre has its own recommended inflation pressure marked on the wall use that as a baseline |
Posted: Tue Jun 23, 2009 11:09 am Post subject: |
| neckto wrote: | | each tyre has its own recommended inflation pressure marked on the wall use that as a baseline |
you mean maximum?
recommended is normally on the vehicles pillar, by the driver's door. |
cacasplat3 punchin NOS
Joined: 29 Jul 2005 Tech posts: 3170 Location: Where Fuel Is Cheaper Than Bottled Water...... My 2NRide:
Posted: Tue Jun 23, 2009 12:42 pm Post subject: |
^^^the ones on the pillar etc. are usually the minimum pressure.......
tire pressure shouldn't be a function of what your ride quality requirements are, but should be based on safe maximum tire contact area with the road. tire pressure affects the tire's ability to clear water from under it in wet conditions...and as a result is quite an important factor in your car's safety...........
there was a great link posted some years ago with pictures of the contact area at different tire pressures......will go look for it and request that it be stickied  |
Posted: Tue Jun 23, 2009 1:18 pm Post subject: |
yes it is a huge factor, but even in that range, there can be comfort tweaks.
a tire moving at 140km/h, needs to move water faster than one moving at 70km/h,
which one should have the higher pressure? |
Posted: Tue Jun 23, 2009 1:38 pm Post subject: |
| after looking at those images... 35 psi for me! |
Posted: Thu Jun 25, 2009 1:06 am Post subject: |
| ^^^ daz wat i did 2 lol |
