DYNAMAT GEL BATTERIES OPTIMA SUBWOOFERS RE PIONEER ETC
Goto page 1, 2, 3 ... 15, 16, 17  Next
Post new topic   Reply to topic   printer-friendly view    trinituner.com Forum Index -> Car Audio Classifieds
TOIZ WIT NOIZ
Tech posts: 13
PostPosted: Sun Mar 15, 2009 10:51 am
   Post subject: DYNAMAT GEL BATTERIES OPTIMA SUBWOOFERS RE PIONEER ETC
TOIZ WIT NOIZ
MOBILE AUDIO AND ALARMS
#1211 SS ERIN ROAD PENAL
PHONE #682-1100 /392-9585 /FAX 6478-6082
RE AUDIO SUBS[/color]
WE WILL DELIVER ANYWHERE FOR A PRICE CALL FOR FURTHER INFO
[color=red]RE 12 INCH 200WRMS $400.00
RE SR 12 INCH 400W RMS $900.00
* 300W RMS Dual 4 Ohm
* Kraft Pulp Cone
* Pressed Steel Basket
* Double Stack Magnet
* 4-Layer Copper Voice Coil
* FEA-Optimized TG Technology Motor Structure
* Linear Spider
* Foam Gasket
* Electrical Q Value -Qes: 0.41
* Mechanical Q Value -Qms: 4.99
* Total Speaker Q Value -Qts: 0.38
* Free Air Resonance -Fs: 23.6 Hz
* Equivalent Compliance -Vas: 85 liters
* One-Way, Linear Excursion -Xmax: 18 mm
* Efficiency -SPL 1W/1m: 86.2 dB SPL
* Effective Piston Area -Sd: 480 cm^2
* DC Resistance -Re: 1.8 ohm
* Nominal Impedance -Znom: Dual 4 ohm
* Thermal Power Handling -Pe: 300 W
* Force Factor -Bl: 14.35
RE SE 12 INCH 600 W RMS $1200.00
* Impedance : Dual 4 ohm voice coils 600 watts true RMS Power! (No bootleg power ratings like cheaper brands, this is a huge 20 pound subs!)
* Efficiency - SPL 1W/1m: 83.2 dB SPL
* Effective Piston Area -Sd: 310 cm^2
* DC Resistance -Re: 2.8 ohm
* Mounting Depth - 6"
* Mounting Hole Diameter - 9.25"
* Overall Diameter - 11"
* Bolt Hole Circle - 10.125"
* Motor Width - 6.25"
* Motor Depth - 3.25"
* Basket Depth - 2.75"
* Displacement - .14 cu. ft.
* Weight - 20 lbs.
* Dual Composite 2-piece Cone
* Rubatek Foam Surround
* Cast Aluminum Basket
* Tork-Tite Terminal
* 3" 4-layer Aluminum Voice Coil
* FEA Optimized Motor Structure
* Triple Stack Maganets
* Progressive Spiders
* Qes: .46
* Qms: 4.4
* Qts: .42
* Free Air Resonance -Fs: 26.6 Hz
* Vas: 31 liters
* Wrap around Rubber Gasket
RE SR 10 INCH 300 W RMS $650.00
* Kraft Pulp Cone
* Linear Spider
* Foam Gasket
RE SE 10 INCH 600 W RMS $1100.00
* Weight - 20 lbs.
* Qes: .46
* Qms: 4.4
* Qts: .42
* Vas: 31 liters
RE SX 10 INCH 1000W RMS $1800.00
* Dual composite 2 piece cone Rubatek foam surround
* Cast aluminium basket
* Tork-Tite terminal
* 4 layer copper voice coil
* FEA optimized TG technology motor structure
* Triple stack magnets
* Progressive spider
* Wrap around rubber gasket
* 1000W RMS
* Dual 2 Ohms
* Mounting Depth: 7.75”
* Electrical Q Value -Qes: 0.38
* Mechanical Q Value -Qms: 4.7
* Free Air Resonance -Fs: 27.8 Hz
* Equivalent Compliance -Vas: 126.3 liters
* One-Way, Linear Excursion -Xmax: 22 mm
* Efficiency -SPL 1W/1m: 90.4 dB SPL
* Effective Piston Area -Sd: 810 cm^2
* DC Resistance -Re: 1.9 ohm
* Force Factor -Bl: 21
RE SX 12 INCH 1000W RMS $2000.00
* 1000W RMS
* Dual 2 Ohms
RE SX 15 INCH 1000 WRMS $2200.00
* 1000W RMS
* Dual 2 Ohms
RE XXX 15 INCH ONLY ONE MORE $5000.00
* 15" XXX-Series Subwoofer
* 2000 Watts RMS
* Dual 2 Ohms
* Dual Composite 2-Piece Cone
* Rubber Surround
* Integrated Gasket
* Cast Aluminium Basket
* Tork-Tite Terminals
* 3" 4-Layer Flatwind Aluminium Voice Coils
* Split Coil Design
* VMS Vented Magnet System
* Dual Progressive Spiders
* Integrated Tinsel Leads
* Electrical Q Value -Qes: 0.58
* Mechanical Q Value -Qms: 3.62
* Total Speaker Q Value -Qts: 0.501
* Free Air Resonance -Fs: 19.10 Hz
* Equivalent Compliance -Vas: 207.0 liters
* One-Way, Linear Excursion -Xmax: 54 mm
* Efficiency -SPL 1W/1m: 85.81 dB SPL
* DC Resistance -Re: 4.2 ohm
* Nominal Impedance -Znom: Dual 2 ohm
* Thermal Power Handling -Pe: 2000 W
* Force Factor -Bl: 18.16
MTX THUNDER T9515-44 15 INCH $3600.00
Details
Main Features
Manufacturer Sku T9515-44
Brand MTX
Product Line Thunder 9500
Model T9515-44
Size 15 in
Voice Coil Dual
Sensitivity 94 db
Nominal Impedence 4 Ohms
Min Frequency Response 32 Hz
Max Frequency Response 150 Hz
Power
Peak Power Handling 2000 Watts
RMS Power Handling 1000 Watts
KICKER C12 4OHMS 300W RMS $450.00
Kicker 08S8L74
8" 900W Dual 4-Ohm Subwoofer $1300.00
Technical Specification
* Sensitivity: 83.6 dB
* RMS Power Range : 450 Watts
* Peak Power Handling: 900 Watts
* Impedance: Dual 4 Ohm
* Low Frequency response: 28 Hz
* High Frequency Response: 100 Hz
* Diameter: 8 Inch
Features
* Solo-Baric L7 Series
* 8" subwoofer with dual 4-ohm voice coils
* Square SoloKon polypropylene cone with Santoprene rubber surround
* Aluminum basket
* Sealed box volume: 0.33-0.75 cubic feet
* Ported box volume: 0.66-1.00 cu. ft.
* mounting depth: 4-3/4"
* Priced per speaker
KICKER 12 INCH L7 750 W RMS $1900.00
KICKER SOLO BARIC S12C 750W RMS $1300.00
Model Solo Classic 12
Size (IN.,CM) 12, 30
Impedance (OHMS) 2 or 4 DVC
Max Rec Amplifier Power (WATTS PEAK/RMS)* 1200/600
Sensitivity (dB 1w/1m) 88
Frequency Response (Hz) 20-100
Mounting Depth (IN.,CM) 6-5/16, 16
Mounting Cutout (IN.,CM) 11-1/8, 28.3
Rec. Sealed Box Volume (CU. FT., Liters) .88, 24.92
SOUNDSTREAM 12 INCH XPRO 600 W RMS $ 500.00
ROCKFORD FOSGATE (BLACK) 12 INCH P3D412 500 W RMS $ 1000.00
PIONEER SUBS
PIONEER CHAMPION SERIES 1200 WATTS 258 D4/D2 $450.00
Brand: Pioneer RMS Wattage: 350
Model: tsw258d2 ts-w258d2 tsw258-d2 tsw-258 Voice Coil: Dual
Size: 10 inches Condition: New
PIONEER CHAMPION SERIES 308 D4 /D2 (NEW MODEL 1400W) $550.00
HIFONICS OLYMPUS OLM2412 2400 RMS 12 INCH
$1800.00
TECH SPECS
Advertised Power Handling 2,400 Watts RMS
Frequency Range 10-300Hz
Sensitivity 87dB/SPL @ 1.0W
Nominal Impedance 2 ohms per coil
Electro Mechanical Parameters
Revc= 5.000 Ohm
Fo= 27.287 Hz
Sd= 53.000m M²
Vas= 1.944 Ft³
Cms= 138.026u M/N
Mmd= 239.457m Kg
Mms= 246.473 g
BL= 25.373 T·M
Qms= 4.089
Qes= 0.328
Qts= 0.304
Levc= 2.506 mH
No= 0.330 %
SPLo= 87.198 dB
CONCLUSION
ORION HP SERIES 12 INCH 600W RMS
$ 600.00
T3 AUDIO
T 10S4 SINGLE 4 OHM 300 W RMS $350.00
T 10D4 DUAL 4 OHM 300 WRMS $350.00
T 12S4 SINGLE 4+DUAL 4OHM 400 WRMS $400.00
TS12S4 SINGLE 4+DUAL 4 OHM 600 W RMS $1200.00
TSS 15D2 DUAL 2 OHM 1000 W RMS $2500.00
ORION HCCA 12.2 $3000.00
These SPL woofers are most impressive. Orion HCCA subwoofers might possibly be the baddest subs on the planet. Hands down. With its massive 4" high temp voice coil and immense motor, this subwoofer can reach as much as a 4" excursion. A higher excursion equals more bass! Orion HCCA subs have a long history of competition dating back 8-years or more. Why are they so efficient? Why are there so many positive reviews?
Orion made these subwoofers with extreme quality control. They listened to the SPL crowd and dished out a high powered durable subwoofer that can handle its own weight in a match. To keep your sub going Orion offers a field replaceable cone kit so you're never out of the game. Everything on this woofer is enhanced from its voice coil cooling system to the conex spiders. This sub will take whatever you throw at it and trust us, it is power hungry.
* 12" Dual 2 Ohms HCCA Series Subwoofer
* Power Handling:
o Peak: 4000 watts
o RMS: 2000 watts
* Impedance: Dual 2 ohms
* Polypropylene cone
* Wide foam surround
* Dual Flat Conex Spiders with Loop/Stitched Tinsel Lead
* Field Replaceable Cone / Voice coil / Spider Assembly
* 4” copper Wound Voice Coil on an Aluminum Former, High temperature PAARC (Polyester Amide, Amide Resin Coated)
* Enhanced voice coil cooling system (forced convection – aluminum heat sinking – shorting rings to reduce inductive heating)
* Sensitivity: 84 dB
* If you blow the subwoofer, there is a replacement cone kit that allows you to easily swap out the blown/burned voice coil and surround with a new one. The replacement kit allows you to keep the magnet and basket, therefore saving money as you do not need to buy a new sub.
STINGER BATTERIES
STINGER SPV 44 YELLOW TOP $1350.00
STINGER SPV 70 YELLOW TOP $1800.00
STINGER SP1000 RED TOP $2000.00
STINGER SP2150 RED TOP $3500.00
OPTIMA BATTERIES
OPTIMA D 31A $1900.00
OPTIMA D 34 $1700.00
[size=18]XS POWER BATTERIES
[/size]
POWER MASTER D925 $1200.00
POWER MASTER D 975 $1200.00
POWER MASTER D1200 $1400.00
Dynamat 10455 Xtreme$1100.00 9 sheets $125.00 per sheet
* Nine 18" x 32" sheets o aluminum-coated for heat-resistance
* increased flexibility
* high tack permanent adhesive
* Dynamat Xtreme: Dynamat Xtreme provides 4 times the damping efficiency of Original Dynamat, the conforming ability of Premium Dynamat, and the radiant energy reflection of Super Dynamat. Dynamat Xtreme has an aluminum layer for high-temperature areas and requires "no heat" for an easy, moldable installation.
* Self-Adhesive Sheets: Each sheet has a high-tack permanent adhesive with a peel-off plastic liner on the back of the Dynamat Xtreme.
* Easy-to-Cut Materials: All materials cut easily with scissors or a razor knife.* Each Sheet: L=32", W=18", Thickness=
DHD NTX 2.2 FARAD CAPACITOR $300.00
# Capacitance: 2,000,000uF (±10%)
# Max Voltage: 24 VDC
# Max Temp: 95°C
# LED Voltage Digital Display
# Built-In Relay
# Power-On LED Indicator
# Polarity Protection
# Mounting Brackets Included
# Platinum Finish
# Gold Plated Terminals
Massive AudioCAP4 4 Farad Power Cap $500.00
Automatic Standby Mode
Extreme Low ESR for Fast Charge/Discharge
3 Digit Precision Display
IF IN TERESTED PM ME OR CALL FOR FURTHER INFO
MY OTHER STUFF FOR SALE
F.S PIONEER, CLARION ETC CD, USB, DVD, DECKS, SCREENS, ALARMS ETC
http://forums.trinituner.com/forums/viewtopic.php?t=237747
F.S EMINENCE, 18 SOUNDS, RCF,CIARE , SELENIUM SREAKERS+DRIVERS
http://forums.trinituner.com/forums/viewtopic.php?t=236838
AMPLIFIERS, PRE AMPS, CROSSOVER, MONO BLOCK WE PIPING OUT THIS
http://forums.trinituner.com/forums/viewtopic.php?t=237763
F.S SUBWOFFERS AND GEL BATTERIES MUST SEE RE,MTX,ORION,ETC..
http://forums.trinituner.com/forums/viewtopic.php?t=237432
LAMBO DOORS 90 DEGREES, STROBE LIGHTS ,H.I.D,LIGHTS
http://forums.trinituner.co...&postorder=asc&highlight=
Last edited by TOIZ WIT NOIZ on Tue Oct 27, 2009 12:52 pm; edited 33 times in total
TOIZ WIT NOIZ
Tech posts: 13
PostPosted: Fri Aug 21, 2009 12:33 pm
all items in stock
TOIZ WIT NOIZ
Tech posts: 13
PostPosted: Fri Aug 21, 2009 5:59 pm
cheapest around
TOIZ WIT NOIZ
Tech posts: 13
PostPosted: Sat Aug 22, 2009 6:09 am
big sale
TOIZ WIT NOIZ
Tech posts: 13
PostPosted: Sat Aug 22, 2009 11:50 am
Laughing Laughing Laughing
TOIZ WIT NOIZ
Tech posts: 13
PostPosted: Sat Aug 22, 2009 7:42 pm
numb
TOIZ WIT NOIZ
Tech posts: 13
PostPosted: Sun Aug 23, 2009 9:35 am
certified cheapest
TOIZ WIT NOIZ
Tech posts: 13
PostPosted: Sun Aug 23, 2009 9:13 pm
Laughing Laughing
TOIZ WIT NOIZ
Tech posts: 13
PostPosted: Mon Aug 24, 2009 9:59 am
Rolling Eyes Rolling Eyes
TOIZ WIT NOIZ
Tech posts: 13
PostPosted: Mon Aug 24, 2009 1:47 pm
Wink Wink
TOIZ WIT NOIZ
Tech posts: 13
PostPosted: Mon Aug 24, 2009 5:12 pm
Wink Wink
TOIZ WIT NOIZ
Tech posts: 13
PostPosted: Mon Aug 24, 2009 9:21 pm
TOIZ WIT NOIZ
Tech posts: 13
PostPosted: Tue Aug 25, 2009 8:43 am
Tech posts: 3
PostPosted: Tue Aug 25, 2009 11:47 am
IM LOCATED IN S/GRANDE IM INTERESTED IN QUITE A FEW OF YOUR PRODUCTS HOW MUCH WILL TRANSPORT BE?IM LOOKING FOR
1 12'' RESX
1 AMP OF YOUR CHOICE FOR THIS SUB IM LOOKING AT THE XTERMINATOR MONO
2 10'' 18SOUNDS
2 TWEETERS
1 AMP OF YOUR CHOICE TO PUSH THE TENS AND TWEETERS
I PREAMP
CAN YOU PLEASE GIVE ME THE BEST PRICE U HAVE TO OFFER ON THIS SET UP AND HOW DO U THINK IT WILL SOUND.REPLY SOON IM LOOKING FOWARD TO YOUR RESPONSE.IM LOOKING FOR TRANSPORT COST AS WELL THANKS.
TOIZ WIT NOIZ
Tech posts: 13
PostPosted: Tue Aug 25, 2009 12:00 pm
the furthest i will reach is trincity mall call me for more info
ChipSetTrading
Tech posts: 31
PostPosted: Tue Aug 25, 2009 1:58 pm
What is the Ah rating on this model ?
View user's profile Send private message Send e-mail Visit poster's website MSN Messenger
TOIZ WIT NOIZ
Tech posts: 13
PostPosted: Tue Aug 25, 2009 7:29 pm
chipset pm sent
TOIZ WIT NOIZ
Tech posts: 13
PostPosted: Wed Aug 26, 2009 9:10 am
TOIZ WIT NOIZ
Tech posts: 13
PostPosted: Wed Aug 26, 2009 4:33 pm
TOIZ WIT NOIZ
Tech posts: 13
PostPosted: Wed Aug 26, 2009 9:34 pm
bump
Post new topic   Reply to topic   printer-friendly view    trinituner.com Forum Index -> Car Audio Classifieds All times are GMT - 4 Hours
Page 1 of 17
