18 SOUNDS / EMINENCE / SELENIUM / RCF / SPEAKERS & DRIVE
Goto page 1, 2, 3 ... 16, 17, 18  Next
Post new topic   Reply to topic   printer-friendly view    trinituner.com Forum Index -> Car Audio Classifieds
TOIZ WIT NOIZ
Tech posts: 13
PostPosted: Wed Mar 11, 2009 8:25 pm
   Post subject: 18 SOUNDS / EMINENCE / SELENIUM / RCF / SPEAKERS & DRIVE
i only have one i located in penal south amp in very good condition call331 -3333
TOIZ WIT NOIZ
Tech posts: 13
PostPosted: Tue Mar 17, 2009 11:57 pm
Toiz wit noiz mobile audio and alarm
#1211 ss Erin road penal
Phone # 392-9585/682-1100/fax 647-6082
Wholesale and retail
NOBODY beats our prices if see it cheaper let us know
YES WE DELIER
SELENIUM 6W4P 6 INCH 100 WATTS RMS 8 OHMS $225.00 EACH
Nominal diameter: 6"
Nominal impedance: 8 Ohms
Minimum impedance @ 300 Hz: 7.0 Ohms
Power handling peak: 400 W
Sensitivity (2.83V@1m) averaged from 80Hz to 9kHz: 91 dB SPL
Power compression @ 0 dB (nom. power): 3.6 dB
Power compression @ -3 dB (nom. power)/2: 1.9 dB
Power compression @ -10 dB (nom. power)/10: .3 dB
Frequency response @ -10 dB: 80Hz - 9kHz
[color=red]EMINENCE[
6 inch alpha $250.00
6" woofer
8 ohms
85Hz-6kHz
ALPHA 6"
100 watts RMS
Available in 8 ohm
EMINENCE 8 inch. Beta. $275.00
BETA 8" woofer
8 ohms
78Hz-4.5kHz
225 watts RMS
EMINENCE DELTA PRO $400.00
Delta Pro-
8 ohms
100Hz-3kHz
225 watts RMS
450 watts program
High efficiency of 97.8dB SPL!
18 SOUNDS
EIGHTEEN SOUNDS 6INCH 6ND410 $650.00
EIGHTEEN SOUNDS 8 inch. 8m400. $660.00
EIGHTEEN SOUNDS 10 inch. 10m600 $850.00
RCF
[size=18]8 inch. mb8g200 $850.00
RCF 10 inch. L10/750YK $1200.00
PYLE PRO PDBT18 $130.00 A PAIR
Pyle PDBT28 Car Tweeter $150.00 each
Product Description
# 1'' titanium super tweeter
# Diamond chrome cutting finish
# Die-cast aluminum frame
# 1'' high temperature kapton voice coil
# 30 oz magnet structure
# 150 Watts RMS/300 Watts peak
# Frequency response: 2kHz - 20kHz
# Includes mylar crossover capacitor
PYLE 1.5'' HEAVY DUTY TITANIUM SUPER TWEETER - PDBT38 $250.00 each
More Info & Product Specifications:
* 1.5'' Titanium Super Tweeter; * Diamond Chrome Cutting Finish; * 1'' High Temperature Kapton Voice Coil; * 30 oz Magnet Structure; * 150 Watts RMS/300 Watts Peak; * 4-8 Ohms Impedance; * Die-Cast Aluminum Frame; * Ferro Fluid Enhanced Voice Coil; * Sensitivity: 104dB; * Frequency Response: 2kHz - 20kHz; * Mylar Crossover Capacitor Included; * 3.9'' Diameter - 2.6'' Mounting Depth
# Product also known as: PDBT38
BRAND NEW American Accessories AS-3352 300W Built-in Crossover $25.00 PAIR
FeatureS
built in crossover
easy installation
works with existing radio
no amplifier needed
fits in most placeS
no magnetic field
Specifications
max power – 300W/pair
max continuous power – 150W
sensitivity – 92dB @ 1W/1M
frequency response – 2kHz – 20kHz
built-in crossover – 4.7µF/50V capacitor
rated impedance – 4 ohms
POWER ACOUSTIC NB-1 TWEETERS 200 WATTS $70.00 PAIR
SELENIUM TWEETER ST200 $200 EACHJ
Product Description
Product Description
* RMS= 70 * Musical program power= 140 * Impedance= 8 * SPL 1 W @ 1m= 105 * Diaphragm= Phenolic * Cut freq at 12 dB/Oct= 5,000 * Dispersion 46= 40?H x 40?V * Voice coil diameter mm= 46 (1.75) * Magnet weight g= 220 (7,72) * Cover/base material= ABS X17 plastic
POWER ACOUSTIC BLT-5 $170.00 A PAIR
SELENIUM D 250 X COMPRESSION DRIVER$300.00
D250-X
* Specifications:
* Nominal Impedance 8 OHMS
* Power Handling: 150 W (w/ 500Hz Crossover) 200 W (w/ 1,000Hz Crossover)
* Sensitivity: 107db 1W/1M
* Frequency Response 1,500Hz-15kHz
* Magnet Weight: 11.7oz
* Voice Coil 1"
* Gross Weight: 2.99 lbs
SELENIUM D305 COMPRESSION DRIVER $750.00
Diâmetro da Boca: 2"
Potência RMS (W): 75
Potência Prog. Musical (W): 150
Impedância (ohms): 8
SPL 1 W @ 1m (dB): 110
Resp. Freq. @-10 dB (Hz): 400 a 9k
Peso do Ímã (g): 1.600
Diâmetro da Bobina (mm): 75
Freq. Corte a 12 dB/Oit (Hz): 1000
Corneta Usada nos Testes: HL47-50-SLF
Material do Diafragma: Fenólico
Conexão com a Corneta: Flange
Material da Tampa/Base: Plástico
seleniumDriver D405 $1200.00
This Selenium driver features a 2” (50 mm) exit compression driver for high sensitivity, low distortion and smooth medium frequency response applications. That leads the D405 driver to deliver high performance, high quality and high value for the pinnacle in sound reinforcement applications. Its construction features include:
Ferrofluid (Ferrosound ) loaded gap reducing heat build-up and offering consistent results over long-term demanding concert usage;
Voice coil is made of high temperature wire wound on Kapton former to withstand high operating temperatures;
Injected plastic housing;
Precisely engineered diaphragm structure and alignment mechanism allows for easy, reliable and cost effective repair in case of diaphragm failure. If you are not willing to make the repairs, International Audio is the authorized repair center for the USA.
# Specifications:
# Nominal Impedance 8 OHMS
# Power Handling: 150 W (w/ 500Hz Crossover) 200 W (w/ 1,000Hz Crossover)
# Sensitivity: 110db 1W/1M
# Frequency Response 300Hz-7kHz
# Magnet Weight: 11.7oz
# Voice Coil 4"
# Gross Weight: 18.78 lb
Selenium D220Ti-8 1" Titanium Horn Driver 8 Ohm 1-3/8"-18 $400.00 each
Selenium D220Ti 1" high frequency compression driver. The D220Ti replaces the D205Ti and D210Ti. If you have a bolt-on D205Ti, you need the PC-25 adapter.
Power Rating: 80W RMS
Frequency Response: 1000-21kHz
Sensitivity: 109db
Impedance: 8 ohms
Voice Coil: 1.7"
Diaphragm: Titanium
Magnet Weight: 24 oz. Screw-on only
SELENIUM ND2500TI NEODYNIUM COMPRESSION DRIVER $600.00
Model D2500Ti-Nd is a compression driver with exceptional quality. It can be used in line array boxes, sound reinforcement, PA, monitors or drop-down box where it needs to be lightweight with high sound pressure, sound reinforcement and fixed in gyms, parks and exhibition grounds. E. This performance is achieved by the excellent combination of its components. O. The Neodymium magnet assembly is lighter and higher density of magnetic flux. . The dome type diaphragm is specially designed in pure titanium. . Are more rigid structure due to its surface, which ensures light weight and excellent mechanical strength when exposed to high power. . The suspension has a special. O. The acoustic transformer "Phase Plug", injected into pastic of art, with several openings optimized to eliminate undesirable phase cancellation. . The coil is made with wire CCAW (copper clad aluminum wire), high temperature resistant and rolled into a Kapton, resulting in a set of great stability and strength. O. All mobile (RPD220Ti) has a perfect centering, is also easy to exchange in case of any defect.. In the case of exchange of repair, follow carefully the instructions contained in a leaflet to prevent damage caused by incorrect mounting. . The lid of aluminum injected promote better heat dissipation structure and give the driver great robustness.. The model Nd D2500Ti OMF has fixation with screws in the flange.
· Impedance: 8 ohms
· Throat diameter: 50mm
· Neodymium Diaphragm
·· Power RMS: 60 watts
·· Power PMPO: 120 watts
·· Frequency Response: 1000 Hz - 22 kHz (-10 dB)
· SPL: 111 dB · SPL: 111 dB
Coil Diameter: 44 mm
· Weight of Magnet: 115 grams
SELENIUM HL14-50 METAL HORN $250.00
Features:
• Stage monitors, side-fill and P.A. applications.
• Compact size, flat front.
• Aluminum exponential horn.
• 50 mm (2") throat.
• 45° x 45° nominal coverage.
SPECIFICATIONS
Nominal coverage
Horizontal . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 45 degrees
Vertical . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 45 degrees
Directivity
Directivity factor (Q) . . . . . . . . . . . . . . . . . . . . . . . . . . . 21
Directivity index (Di) . . . . . . . . . . . . . . . . . . . . . . . . . . . 13 dB
Sensitivity
On driver, 1W @ 1m, on axis1 . . . . . . . . . . . . . . . . . . . 110 dB SPL
Frequency response @ -10 dB2. . . . . . . . . . . . . . 500 to 25,000 Hz
Throat diameter . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 50 (2) mm (in)
Minimum recommended crossover3. . . . . . . . . . . . . . . . . . . 600 Hz
1 Measured with D3300Ti driver, 2,000 - 17,000 Hz average.
2 Measured with D3300Ti driver.
3 With D405 driver.
ADDITIONAL INFORMATION
Horn material . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . Aluminum
Horn finish . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . Black epoxy
Overall dimensions
Mouth height. . . . . . . . . . . . . . . . . . . . . . . . . . . 156 (6.14) mm (in)
Mouth width . . . . . . . . . . . . . . . . . . . . . . . . . . . 156 (6.14) mm (in)
Length . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 131 (5.16) mm (in)
Volume displaced by horn. . . . . . . . . . . . . . . . . . . . . . 0,9 (0.03) l (ft3)
Net weight. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 670 (1.4Cool g (lb)
Gross weight. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 930 (2.05) g (lb)
Carton dimensions (W x D x H) . . . . . . . . 20 x 19 x 17 (7.9 x 7.5 x 6.7) cm (in)
MOUNTING INFORMATION
Mechanical connection of driver . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . Bolt on
Baffle cutout diameter (front mount). . . . . . . . . . . . . 142 (5.59) mm (in)
Also 6inch door speakers from $150.00 pair
profile 6520 6.5 inch speakrs $150.00
PIONEER 1642 6.5 INCH $300.00 PAIR
TSG1642R
Pioneer TS-G1642R 6.5" 2-way Car Speakers (Pair) Model TSG1642R Part No. TSG1642R
2-way car speakers for 6-1/2" and 6-3/4" locations (pair)
Injection-molded polypropylene (IMPP) composite woofer cone with cloth surround
1-3/16" PEI film dome tweeter
Power range: 2-30 watts RMS (180 watts peak power)
Frequency response: 40-30,000 Hz
Sensitivity: 90 dB
Mounting tabs for use in 6-3/4" openings
Top-mount depth: 1-11/16"
Grilles Included
Sold in Pairs
6x9 speakers from $250.00
profile 6920 6x9 speakers
PIONEER TS-6963 6X9 $450.00 A PAIR
* 6" x 9" 3-Way Speaker
* 270 watts Peak / 40 watts RMS
* Frequency Response: 28 - 28,000Hz
* Sensitivity: 93dB
* Impedance: 4 ohm
* Mounting Depth: 2-5/6"
* Surround Material: Foamed Rubber
* Cut-out Dimensions: 6" x 8-2/3"
* "Open and Smooth" Sound Design
* Carbon Graphite IMPP Interlaced Aramid/Basalt Fiber Cone
* Speaker Grille Included
PIONEER TS-A6993R 5 WAY 460 WATTS $700.00
RMS Wattage: 80
TYPE 6X9
SELENIUM 6TR4A 6.5 INCH FULLRANGE SPEAKERS $$300.00 APAIR
120WATTS MAX 60 WATTS RMS
MY OTHER STUFF FOR SALE
F.S PIONEER, CLARION ETC CD, USB, DVD, DECKS, SCREENS, ALARMS ETC
http://forums.trinituner.com/forums/viewtopic.php?t=237747
F.S EMINENCE, 18 SOUNDS, RCF,CIARE , SELENIUM SREAKERS+DRIVERS
http://forums.trinituner.com/forums/viewtopic.php?t=236838
AMPLIFIERS, PRE AMPS, CROSSOVER, MONO BLOCK WE PIPING OUT THIS
http://forums.trinituner.com/forums/viewtopic.php?t=237763
F.S SUBWOFFERS AND GEL BATTERIES MUST SEE RE,MTX,ORION,ETC..
http://forums.trinituner.com/forums/viewtopic.php?t=237432
LAMBO DOORS 90 DEGREES, STROBE LIGHTS ,H.I.D,LIGHTS
http://forums.trinituner.co...&postorder=asc&highlight=
Last edited by TOIZ WIT NOIZ on Thu Nov 05, 2009 5:07 pm; edited 23 times in total
TOIZ WIT NOIZ
Tech posts: 13
PostPosted: Fri Aug 21, 2009 12:47 pm
Wink Wink
TOIZ WIT NOIZ
Tech posts: 13
PostPosted: Fri Aug 21, 2009 6:00 pm
all items in stock
TOIZ WIT NOIZ
Tech posts: 13
PostPosted: Sat Aug 22, 2009 6:14 am
big sale
TOIZ WIT NOIZ
Tech posts: 13
PostPosted: Sat Aug 22, 2009 11:52 am
Laughing Laughing
TOIZ WIT NOIZ
Tech posts: 13
PostPosted: Sat Aug 22, 2009 7:44 pm
power is all
TOIZ WIT NOIZ
Tech posts: 13
PostPosted: Sun Aug 23, 2009 9:33 am
certified cheapest
TOIZ WIT NOIZ
Tech posts: 13
PostPosted: Sun Aug 23, 2009 9:11 pm
Laughing Laughing
TOIZ WIT NOIZ
Tech posts: 13
PostPosted: Mon Aug 24, 2009 9:58 am
Wink Wink
TOIZ WIT NOIZ
Tech posts: 13
PostPosted: Mon Aug 24, 2009 1:46 pm
Wink Wink
TOIZ WIT NOIZ
Tech posts: 13
PostPosted: Mon Aug 24, 2009 5:12 pm
Wink Wink
TOIZ WIT NOIZ
Tech posts: 13
PostPosted: Mon Aug 24, 2009 9:20 pm
Rolling Eyes Rolling Eyes
TOIZ WIT NOIZ
Tech posts: 13
PostPosted: Tue Aug 25, 2009 8:43 am
TOIZ WIT NOIZ
Tech posts: 13
PostPosted: Tue Aug 25, 2009 12:04 pm
delivery available
TOIZ WIT NOIZ
Tech posts: 13
PostPosted: Tue Aug 25, 2009 5:41 pm
TOIZ WIT NOIZ
Tech posts: 13
PostPosted: Tue Aug 25, 2009 7:30 pm
TOIZ WIT NOIZ
Tech posts: 13
PostPosted: Wed Aug 26, 2009 9:11 am
TOIZ WIT NOIZ
Tech posts: 13
PostPosted: Wed Aug 26, 2009 4:34 pm
TOIZ WIT NOIZ
Tech posts: 13
PostPosted: Wed Aug 26, 2009 9:36 pm
delivery available
Post new topic   Reply to topic   printer-friendly view    trinituner.com Forum Index -> Car Audio Classifieds All times are GMT - 4 Hours
Page 1 of 18
