fastcars Riding on 13's
Joined: 12 May 2007 Tech posts: 1 Location: Ride iN a Bumper hArd!! My 2NRide:
Posted: Fri Nov 28, 2008 9:17 pm Post subject: Re: CLEARANCE !!! New Parts, F/Used Parts, Old Stock etc. |
| partsman wrote: | GHANY'S AUTO SUPPLIES , 25 1/2 mm Naparima Mayaro Road ,RIO CLARO ... If you're coming from the direction of Princes town,after the Rio Claro sign look for Sherry's Bar on your right and we are about 100 ft on the left. If you're coming from Mayaro (east), keep going straight after the Rio Claro roundabout, look for the Roman Catholic Church and we would be on the right BEFORE Sherry's Bar.
Phone # 644-1153 (Home) , Cell :753-5228 , 368- 6904.
New Carburetors
Escort Solex type @ 900
Malibu V6 @ 1200
Bedford 6 ton 1500
Mazda , Kia Throttle body @1800
MIG WIRE ROLLS (27 LBS, 040) @ $100
Lot Sale on ALL Mig Wire (100 Rolls) $5000
WIND SCREENS
Front :
MS122,Sunny B11,Mazda 323 RWD, AE101 Sedan &Lift back,
, Civic SR3, RH112, RN85,IsuzuWFR,
&300 N/m, Lancer 91/95, Rosa Bus, T3000, Rx60 , Charmant
RU60, Datsun 1200,1600, B210,310,Cortina Mk2,3.,Hunter,
Datsun 260C, Galant 1600, MS 50,60, Maz 616, Coaster , E20
Mazda B2200, MAz 1500 P'up,Carry ,Jimny,Holden,161,
Pajero91, B/BirdU13,SSS,
Rear : 626FWD, 323 FWD, Isuzu WFR, GAlant A163/A121
B210, Ms50, Maz616, AE80,90,91, Maz B1600,620 P'up,
Sunny,B12, B13,Laser, Rx60, E23,Dat 280C,
LOT SALE ON ALL WIND SHIELDS $30,000
Datsun 280C Parts :
Original Hood Ledge @150 , Original Front Door Post @250 ,
Door Glass @75 , Original Left Side Front Door Skin @100
Rear Wind Shield @250 , Lower Balljoints@99 (AP)
Inner Steering End @60 , Original Rear Stabilizer Bar Rubber @5
Brake Shoe sets @50 , Parts for gas engine
Orig bare lower cradle @100 , 1 only wheel arch @125
Chassis @200, Fender shield@95, w/shield Nickle set @295
Bonnet Nickle @95, Rear coil spring @150,
Hyundai
1 lot new, original hyundai body parts, mechanical parts ,
transmission parts.... too much to mention
Asking $18,000 for all listed parts. All items on sale at
33% discount.
Primera
Trunk lid , tail light, trunk lid light, doors
C32
Grille, fender lamp,some doors, trunk lid,no. plate garnish,
door sensors, wiper motor, disc pads(track) @$ 40
C33
Headlight, grille, doors, tail light, no. plate garnish, brain box,
fender lamp, etc
AE92
grille,headlight, bonnet, tail light, doors ?, wiper motor
323LX
headlight, grille, fenders, doors, rear w/shield, T/lid , Tail lamps
Bumpers, wiper motor
A31
, Doors, Tail lamps, Headlight ,wiper motor, Grille,
Suzuki Carry
Windshield, Taillight , engine parts, track arm , plug wires,
Super carry front bumper, S/Carry windshield .
Suzuki Baleno All New Parts.
Bonnet, L/S Fr Door shell, L/S Rear D/shell, R/s Fender
Suzuki Jimny
Dashboard , Steering Column, Rear door, Disc Pads,
clutch cable, Eng parts, 3 cyl turbo gasket kit, W/shield,
B/shoes, carb kits, Rear Hub, etc.
Parts for Suzuki Carry also available .
B12
Head lights, Tail lights, Grille, Doors, Rear
Bumper, Bare Tail Cut, Rear reflector, Door regulator,
Door motor ?, Dash board, Trunk lid, Front bumper rein-
forcement (new),Rear W/Shield, New velocity joints , pumps
console , some upholstery parts,mounts, etc...
B13
Headlight, tail light, doors, trunk lid, grille, rear w/shield, rear bumper ,front ?, some upholstery parts, door motor, wiper motor, carburetor, alternator, starter ?, BMC kit , Disc pads, W/brg, stg booth ,vel joint boot, ...
B14
Doors (new shells and f/used), Dashboard, 1st model rear
fender (new), Head Lamps,Tail Lamps, Grille ??,
Vel Joint , Stg Colum ?, Upholstery parts ?.
AE92
Front Bumper, New Bonnet , Headlight
grille , coner lamp, Fenders , Doors
Radiator , H/Back Rear Lamp,
B210
Windshield F @250, Radiator panel @350, Stone shield @90
Rear w/shield @200, Rear Bumper @200, H?Br cable @95
L/side Chassis @150 , Fender Rib @20 , Engine parts, etc
Rear lamp @ 125 taiwan ,$295 orig., H/light bowl @45 ,
Starter @350,
B310
: Front bumper (no ends) @200, Grille @ 95, W/shield @295
H/Light Finisher orig @ 95 , corner lamp orig @75
Rear lamp orig @295,W/shield nickle set @200 , Engine parts etc
Dat 1200
: F/used Dashboard @500, Front Bumper orig @300
,W/shield ? @ 350, Rear Lens @50, Track arm @100,
Stone shield nickle @95, Engine parts & other parts.
Fuel pumps, Drag link, Gaskets, Roller brgs, H/b Cable
Valves, B/Shoes, Idle Arm, Pitman Arm
Dat 1600
: Fr L/s ind lens orig @50, Apron @ 250, W/shield @350,
Doorskin @200, rocker panel @50,Piston & Rings,
Stg ends , B/joints,Eng Brgs, Rings, Wheel Brgs, B/Shoes,
Gasket Kits, Hand Br Cables, G/box mtg
Ford Cortina
Stone shield, Mk3/4/5 Grille, headlamps, Bonnet locking panel, R/s Mk4 Fender, Apron, Door skins, L/S fr & Rear Mk 5 Door Shells, Mk4 Ind, Door glass, panels, mk4 rear lamps,Mk5 L/s rear lamp, no. plate light, Mk4 & 5 bumpers, Gas tanks, gas tank guage, complete upper cradle,
cradle bushings, upper b/joint, stg ends, eng parts, boot rubbers, stg coupling, drive shafts, seals, 2000 R/W brg, 2000 W/Cyl, Tawa, elec parts , C3 &C4 Trans kits & parts, fuse box, 1600 Japanese Starter ....and some more
Escort
Sq grille, Round H/light &Bowl, Rear D/Skins, Black Bumper, Panels, Eng Parts, starter, elec parts, seals, bumper lamp, etc
E20 /b]
W/shield, Grille, Finisher, Side glass, Fender, orig
Draglink, stg end assy w/bamboo, Balljoint, b/shoes,
Eng parts, H/b cable,
[b] E24 NEW PARTS
Bare Dash, F/Fender, Tail lamp, Wiper Motor, Disc Pads
Some TD27 Engine Parts .... and more.
Mazda 616
Grille, L/Side Finisher, Radiator Panel, Fr & R W/shield,
1st Model Tail lamp,Bumper ends ?, panels,Points
Piston & Rings, Eng Brgs, Crankshaft, Rings, Dist ?,
Dist Cap, Rotor, Condenser, Oil Pump, Carb Parts, Starter
Alternator, Stg Colum bush, Timing Chain, Gaskets ?,
Mounts, Tensioners, Ladders, Seals,Disc Pads, Stg ends,
Ball Joints, Br adjusters, Plug Wires, Hand Br Cables,
Tawa, Draglink, Pitman arm , Idler Arm,Water Pump
Mazda Rx2
Front Plate only, Water Pump, Points, Plugs ,Rotor
626 FWd GLX
: GLX Fenders @95 (new), Door Post @50,
Doorskin @ 40, Tail Lights f/used , Head Lights F/use
@ 250 , Door glass @ 25, Doors F/use @ 300, rear w/shield
@250, engine parts etc
626 MX
Grille @100, Headlights @ 275, Doors (no sets) @ 300
Trunklid @300, Tail Lights @ 250.
March
Headlights, Tail lights, Front fender (orig),Doors, Rear
Bumper, Rear fender (new), Some engine and
suspension parts.
Lancer RWD
Orig front and middle door post $95, Rear W/shield $250,
New Door Glass $95, NewRear Bumper Skin $99, Engine
parts, Headlight f/use $150, B/shoes, Rear Disc Pads, Etc..
New Springs
Galant 2000 front and rear Spring @ 225
Holden Front Spring (works on 280C rear) @150
Datsun 120Y Spring @ 175
Main Lift for Escort, Hunter , MK2 Cortina @ 100
Bedford 330 Main Lift @ 300
Helper Spring : $40 (cars), $100 (vans etc)
Pickup ? Coil Spring @200
Lot Sale on ALL Springs $7000.
620 pickup
Stoneshield @50, Radiator Panel @350 ,Doorskin
@ 100, Bumper @$150 , Grille@150,F/ Windshield@
350, R/Wshield @200, R/sTail lamp @60,Rear W/S
Rubber @50, H/br Cable @50, Head light Bowl @50
Apron @250, Tail light Fin @75, Fuel pump,Eng Parts
King Pin Kit,Brake Shoes.......etc
720 Pickup
Stg end Assy (2 ends and bamboo) Japan $ 125
Apron (orig old stock) $300, Cabin Rear post $ 150
Some engine parts available, Brake Shoes
Old model front bumper $ 200, Rear bumper footrest
$100, Bumper bracket $ 95 maybe some more parts
Holden
Idler Arms, Upper Cradle, Upper Balljoint, Rear Lens,
Engine Parts, Stg Worm, Diff Kits, R/W Brg, Seals,
Gaskets?, Trans Kits, Filters, Bumper strip, Cross,
Grille, Distributor, Carb Kits,Commodore Panel,
Commodore fender
Sunny B11
Headlight bowl, Grille, apron, tail lamp, bumper ends,
Front Hub (orig), Headlamp, rear w/shield,
Stg column, Eng parts, Bushings,V/Joints, chrome
bumper front strip & ends, F/use dashboard,
F/used Head, wiper motor, center console etc
[b]NEW PICKUP BODY PARTS FOR RANGER, VIGO,FRONTIER
We don't have these in stock but they're available upon request :
Ranger TBR model : Headlight, Grille, Park Lamp
TBJ Model : Fenders.
Vigo : Tail Light, Head Light, Bumpers, Grille
Fender, Bonnet
Frontier TCD Model : Grille, bumper, Radiator Panel,
Fenders,Tailgate, Tail Lamps,
Galant A121, A132, A163 NEW PARTS
Original Apron $150, Fender Skirt$95, Fender Shield$75
Crankcase shield $40, Doorglass$50, F/Doorpost $99
Middle Doorpost $99, A121 F/Windshield$299, A121,163
Rear/W/Shield $299, Gal Wagon L/S/Rear Door Skin$99
A121 orig Rear lamp $350,Gear Shifter $95, A121 Rear
Bumper $199, A121 Fender $196, A121 Corner Lamp$40
Gal Eng Mt , Gal2000 springs, Engine Parts, some susp
parts, Acc cables $29, Orig H/Brake Cable $199, f/use
wiper motor $200, F/use A121 Rear lamp $200, Bushings
#194 oil filter $16, Door Hinge$30, and lots more ...
Old Model American
This is a general list . we would like to sell all as a lot. Price $ 30,000.
Chev cross, Shocks, Carb Kits,Water pumps, Oil pumps,
Bendict Drives, Transmission Kits, 2 New Transmissions
Ball joints,Steering ends, Air Filters, oil filters,Mounts
Disc Pads, Br/Master Cyl Kits, Center brg ?, Diodes,
Malibu V6 Carburetors, Alt Regulators, Gaskets, Plugs
Plug Wires, Dist. Caps, Piston &Ring Sets, Engine Brgs,
Rings Sets, Bumper riders, Rear Brake Hardware kits,
Chev '91 Windscreen Ex pipe Gaskets, Push Rods,
Hydraulic Lifters, Rotor Disc , Dist. Rotor , Points, etc.
All old stock parts for the following OLD MODEL vehicles on sale :
FORD , HILLMAN , AUSTIN, VAUXHALL, OPEL, VOLKSWAGEN, BEDFORD, FORD TRUCK, LEYLAND TRUCKS, O/M TRACTORS, MOTORBIKE, FIAT,
ZASTAVA, AND OTHER VEHICLES SO OLD, YOUR GRANDFATHER WASN'T EVEN BORN YET.
FOREIGN USED PARTS
Headlights : Laurel C32, C33, 626MX, GLX, March K10, 323LX, Lancer Rwd
Lancer CK, Mirage, Ms137, Rx60, Honda ?, Medallist, etc
Doors : Rx60,70,80, AE 80,90,91,92, MS 121,137, C32,33 , b12,13,14
B/Bird 910,SSS , Cefiro, Cilencia, Medallist, 323 Glx, Honda
EE91,March etc
Bumpers : Ae91,92,100, B12,B13 ,Medallist , Rx80 , 323 glx, Bmw ,
Volvo,626 RWD Rear, Prelude, EE90,
Trunk Lid : 323 Glx, Laurel C33, Gx81, Cefiro , Ae90,92,80,100,
Accord, B12,13, MS127. etc
Dashboards : Datsun 1200, Sunny B11, Laser, E24, Jimny ,Carry.
We have some overstock /slow sellers that we'll practically give away :
eg : Galant 1600 Camshaft (new) $ 20 DOLLARS !!!
Galant Balance Shaft new $ 20 Dollars !!!
Lots of helper springs for old model english cars $ 30 Dollars !!!
Timing Gears eg 616, Galant $20 Dollars!!!!
Doorskins for 626 FWD, 620 pickup, Commodore, $40 Dollars !!!
Ground Wires ( Pleated or insulated) $20 Dollars !!!!!!!!!
Assorted steering ends , Balljoints , $30 Dollars !!!!!!!!!!
Idler arms, pitman arms $50 dollars !!!!!!!!!!!!
Assorted old model starter , Alt housing ......CHEAP !!!
Lots of parts for Bedford, Ford , Leyland, Trader, Austin Truck,
Land rover , Vauxhall, Hillman , Old model Tractors, etc CHEAP !!!!!!!!
Barrel Shocks $50 Dollars !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Piston Sets, Rings, Engine Bearings, Liners at DISCOUNTED PRICES !!!!
Lock Type Gas Tank covers $ 30 Dollars !!!!!!!!
Hood Racks (F/used) $250 !!!!!!!!!
GREAT DEALS FOR WHOLESALE BUYERS /GARAGES ETC.
SALE ALSO ON ALL MECHANICAL F/USED PARTS.EVERYTHING MUST GO! |
GOOD STUFF I HAVE 2 COME SEE U!!!  |
partsman 3NE 2NR Power Seller
Posted: Sun Nov 30, 2008 1:28 am Post subject: |
| bump |
Conrad TriniTuner 24-7
Joined: 15 Jun 2006 Tech posts: 1729 Location: Shifting into "D" My 2NRide: Nissan A31 Cefiro
Posted: Sun Nov 30, 2008 10:54 am Post subject: |
| Do you have the A31/R32 hand brake lever and center console? |
platters68 Riding on 13's
Posted: Sun Nov 30, 2008 3:56 pm Post subject: |
| ayy parts man do u have an evaporator for d elantra?? pm if u do thanks |
Posted: Thu Dec 04, 2008 12:19 am Post subject: |
| bump |
Posted: Sat Dec 06, 2008 9:35 am Post subject: |
| bump |
Posted: Sun Dec 07, 2008 9:31 am Post subject: |
| bump |
Posted: Thu Dec 11, 2008 9:13 am Post subject: |
| bump |
KrAzYBoY Riding on 13's
Joined: 01 Apr 2008 Tech posts: 13 Location: South My 2NRide:
Posted: Thu Dec 11, 2008 11:16 am Post subject: |
| 323lx/glx power steering rack and bonnet do u have? |
Loud Speed
Posted: Thu Dec 11, 2008 10:05 pm Post subject: |
lookin for ck2 parts
Bumper with brackets and fogs finishers. (preferably with lip.)
grille
head lights. (preferably glass)
bonnet |
88sentra
Joined: 10 Jun 2007 Tech posts: 0 Location: cooper city fl My 2NRide:
Posted: Sat Dec 20, 2008 10:05 am Post subject: |
| Hey whats up partsman tried calling u no anwers and pm no replay |
Posted: Mon Dec 29, 2008 3:03 pm Post subject: |
| bump |
Posted: Tue Dec 30, 2008 9:16 pm Post subject: |
Hey everyone , thanks for your support over the last 6 months . All the best to you and yours and hope everything will be absolutely fine in 09 . God bless .
Salim Mohammed . |
Posted: Wed Dec 31, 2008 1:31 pm Post subject: |
| bump |
Celica GTS Street 2NR
Posted: Wed Dec 31, 2008 4:27 pm Post subject: |
| aye partsman yuh have any parts for the st183 celica im lookin for a complete rear suspension |
Posted: Sat Jan 03, 2009 10:11 am Post subject: |
| bump |
boxz Riding on 13's
Posted: Sat Jan 03, 2009 10:32 am Post subject: |
| what parts do have for rwd box lancer like door interior, dashboard , doors ,all lights ,door rubbers , outside door strips and there prices |
boxz Riding on 13's
Posted: Sat Jan 03, 2009 10:33 am Post subject: |
| and a 1600 compressor |
Posted: Sun Jan 04, 2009 8:42 pm Post subject: |
The only lancer parts i have are the ones listed . Check the thread .
Regards . |
Posted: Mon Jan 05, 2009 10:19 pm Post subject: |
| bump |
You cannot post new topics in this forum You cannot reply to topics in this forum You cannot edit your posts in this forum You cannot delete your posts in this forum You cannot vote in polls in this forum
