3stagevtec punchin NOS
Joined: 12 Jul 2006 Tech posts: 4476 Location: killing two stones with one bird... My 2NRide: Suzuki Grand Vitara
Posted: Mon Jan 19, 2009 11:16 pm Post subject: |
| i know the digital meters used for in car monitoring has an internal potentiometer that you can use to calibrate the meter.. i'm not sure if DMM will have that same ability.. |
Sully Trying to catch PATCH AND VEGA
Posted: Tue Jan 20, 2009 6:10 am Post subject: |
| If you get a Fluke meter then you can have it calibrated at Western Scientific. I don't know how much that costs though. |
kurpal_v2 Riding on 16's
Joined: 28 Dec 2007 Tech posts: 1146 Location: shaking down my bhaji tin My 2NRide:
Posted: Tue Jan 20, 2009 8:04 am Post subject: |
| ^^$25usd craftsman, I thought it would have been the basic thing I wanted but like cheap thing noo good.. |
Posted: Tue Jan 20, 2009 8:08 am Post subject: |
| silent_riot wrote: | | IIRC the digital mutlimeters take their reference potential from the battery. So if that is off, the readings would be off. In my meter i used to get 17V when the batt was bad. I changed the batt and readings were normal. |
Wait a minute, damn right, I took a ole battery from a next ole DMM that I thought was off and giving me off readings...Dude you rawk.. *runns off to get 9v* |
Posted: Sun Apr 05, 2009 11:54 am Post subject: |
| kurpal_v2, Does it have to be that long, or will a shorter one suffice? |
audioholic big D Street 2NR
My 2NRide: Toyota Cressida
Posted: Sun Apr 05, 2009 7:40 pm Post subject: |
| I used the Dewalt mag. bit holder with the guide works great perfect length as well.... |
pioneer punchin NOS
Joined: 18 Apr 2003 Tech posts: 4030 Location: Harmony|Chaos My 2NRide: Toyota
Posted: Sun Apr 05, 2009 10:50 pm Post subject: |
| I told him about the Dewalt long time now, but he doh listen as usual. |
Posted: Mon Apr 06, 2009 8:34 am Post subject: |
| Sully wrote: | | kurpal_v2, Does it have to be that long, or will a shorter one suffice? |
Shorter is better and I took your advise pios..  |
pioneer punchin NOS
Posted: Thu May 14, 2009 11:13 pm Post subject: |
Hey dudes, well my pricesmart mc culloch hammer drill finally gave out on me...think it's a trigger problem (might cost more to fix than it's worth)
Anyhow, i'm in the process of ordering a Bosch Hammer Drill...i need a hammer drill cuz i bore alot of holes in the walls home to mount speakers (and mammy cussin )
I used my previous hammer drill for screw driving also, do you all think i should buy a smaller drill also to use for driving?...or even those screwguns?...can someone tell me the difference between the two?
When i building something it's a kinda pain to keep switching from drill bit to screw bits...so i wanted a seperate dedicated drill/driver for putting down screws.
What ya'll recommend? |
Posted: Thu May 14, 2009 11:18 pm Post subject: |
| dewalt |
pioneer punchin NOS
Posted: Thu May 14, 2009 11:20 pm Post subject: |
| Dewalt for the small normal drill? |
TheWiseOne 3NE 2NR Power Seller
Joined: 11 Dec 2007 Tech posts: 365 Location: Out of This World My 2NRide:
Posted: Thu May 14, 2009 11:21 pm Post subject: |
^^^^ talk done lol
all my tool are dewalt.... |
pioneer punchin NOS
Posted: Thu May 14, 2009 11:22 pm Post subject: |
so Bosch eh good?  |
(...Rovin...) 3NE 2NR Power Seller
Joined: 21 Jan 2006 Tech posts: 3651 Location: Chaguanas My 2NRide:
Posted: Thu May 14, 2009 11:40 pm Post subject: |
thats y i own 4 drills !
1 craftman 14.4 v cordless for screws in places like d car or up on a ladder or far from a wall socket
1 old time B&D whose rpm only goes up to 650 but it has some power - used to build boxes , screwing & unscrewing only , not drilling with this 1 since d Phillips tip is always kept on it
1 dewalt with d chuck that cud hand tighten , 2500rpm used mainly for pre-drilling mdf for box building & drilling any holes
1 milwaukee hammer drill - goes thru bricks walls like that ... can make holes in concrete beams & good for heavy drilling like flat steel
i always have d B&D & dewalt together when i box building so i dont need to change bits .....i strongly suggest u invest in 2 drills so save on time & energy to switch between drilling & screwing ...
havent used a bosch drill before but i reguard d brand as being damn good since i have a heavy duty grinder from them & nothing stops or slows d power that have
dewalt & milwaukee drills work really good too just check d specs good because there r lower lighter use models ... |
pioneer punchin NOS
Posted: Thu May 14, 2009 11:58 pm Post subject: |
| So a cheaper VSR drill should work for screwing? |
Posted: Fri May 15, 2009 12:05 am Post subject: |
| dont like how those new model orange color B&D looking like its cheaply made , better u try a skil instead if u buying cheap , but i suggest d lower model dewalt for about $900 by bhags ... |
Posted: Fri May 15, 2009 3:53 am Post subject: |
| I use a METABO cordless hammer drill / screw gun 18 V works like a beast .....also i believe Dewalt has one as well ....ie the dewalt is a LIL lighter and smaller but price is a bit higher than the Metabo........ |
pioneer punchin NOS
Posted: Fri May 15, 2009 1:34 pm Post subject: |
| I don't believe in cordless drills as i think they are a waste of money and not efficient as a corded, but thaz jus me. |
X_Factor 30 pounds of Boost
Joined: 27 Apr 2003 Tech posts: 2535 Location: St. Augustine My 2NRide: NISSAN SENTRA b14
Posted: Fri May 15, 2009 5:01 pm Post subject: |
DW508-B3
Dewalt hammer drill
that drill built 2-2 storey houses from start to finish, took reall pressure and still working, bought 4yrs ago |
