turbohead wrote:if is local hilux jus drive in toyota an dey will do for free for u.
yep this true...
then 3 days later the light will come on again...
What TTTL does:
- Unplug the wires to the diesel filter
- Turn ignition switch to ON
- open the drain valve
- pump the primer pump until all water is out
- close the drain valve
- plug the wires into the diesel filter
What I'd recommend:
- buy a fuel filter
- ensure the engine is off
- unplug the wires to the diesel filter
- open drain valve
- open fuel filter canister
- remove fuel filter
- remove canister from vehicle
- thoroughly (and carefully) clean inside of canister
- dry inside of canister (paper towel, compressed air or sun light)
- install canister in vehicle
- install new fuel filter
- close canister
- turn ignition switch to on
- pump the primer pump until diesel comes thru the drain off valve
- close drain off valve
- keep pumping primer until it becomes very hard to press
- plug wires back on the fuel filter
- start engine and let run for a few mins
