AUDIO PIPE MIDS ????? Give views
Goto page Previous  1, 2, 3, 4, 5, 6, 7, 8, 9, 10  Next
Post new topic   Reply to topic   printer-friendly view    trinituner.com Forum Index -> Ole talk and more Ole talk
Racegod
Tech posts: 647
My 2NRide: nissan B-13
PostPosted: Tue May 20, 2008 2:22 pm
crazybalhead wrote:
I going and sell my DLS too. Sad
let me kno when, i need a pair for mih doors... Cool
View user's profile Send private message Yahoo Messenger MSN Messenger
gfbl
Tech posts: 887
PostPosted: Tue May 20, 2008 2:23 pm
3stagevtec wrote:
i real miss out yes... Shocked i just gotta bump this thread...
and believe it or not, the guy STILL hasn't changed... go talk to him and he will continue with his typical lies.. and i have heard quite a few directly from him.. he never learns... Confused
what else he tell yuh?
spam
Tech posts: 876
PostPosted: Sat May 31, 2008 8:58 am
^^^ hahahahaha hear you
first time i seein this ched
SSC wtf man lol
Shocked Shocked Shocked
Tech posts: 4030
My 2NRide: Toyota
PostPosted: Thu Sep 18, 2008 5:58 pm
fuzz_174 wrote:
Southside while i admire your "love" for car audio, i can't handle the lying dred.
I will attempt to expose you a bit
These are the parameters you quoted
southside connections wrote:
audiopipe 10"-
GENERAL SPECIFICATIONS
Nominal Diameter 250/10 mm/inch
Rated Impedance 8 Ohm
Program Power 350 Watts
Power handling capacity 100 Watts
Sensitivity 1W, 1m 98 dB
Frequency Range 70-3000 Hz
Effective Piston Diameter 210/8.3 mm/inch
Maximum Excursion Before Damage 40/1.6 mm/inch
Minimum Impedance 6.7 Ohm
Voice Coil Diameter 76/3 mm/inch
Voice Coil Material CCAW
Voice Coil Winding Depth 6/0.25 mm/inch
Number of layers 2
Kind of layer Outside
Thickness Top Plate Depth 6/0.25 mm/inch
Cone Material No pressed paper
Cone Design Curved
Surround Material Laminated cloth
Surround Design Wave
THIELE - SMALL PARAMETERS
Resonance frequency Fs 80 Hz
DC resistance Re 5.1 Ohm
Mechanical factor Qms 4.9
Electrical factor Qes 0.24
Total factor Qts 0.25
BL factor BL 15.5 T - m
Effective Moving Mass Mms 34 gr
Equivalent Cas air load Vas 25 liters
Effective piston area Sd 0.032 m2
Max. linear excursion Xmax 2.0 mm
Voice - coil inductance @ 1KHz Le1k 1.1 mH
Half-space efficiency Eff 3.24 %
MOUNTING INFORMATION
Overall Diameter 26210.6 mm/inch
Bolt Circle Diameter 25.5/9.6 mm
Bolt Hole Diameter 5.40.13 mm/inch
Front Mount Baffle Cut-out 230/9.1 mm/inch Rear Mount Baffle Cut-out 229/9.0 mm/inch
Depth 120/4.7 mm/inch
Volume occupied by the driver 1.2/0.04 liters/ft3
BAFFLE CUTOUT DIAMETER
Net Weight 6.70/16.9 Kg/lbs
Shipping Weight 6.10/17.8 Kg/lbs
i have to get permission for the graphs so i if i do i will post them Very Happy
these are the Parameters directly off RCF website,
http://www.rcf.it/vediMacro...BassL10/750YK/product.htm
Mid-bass 10", 350W AES, 700W Program
Program Power 700 Watts
Power handling capacity 350 Watts
Sensitivity 100 dB
Maximum Excursion Before Damage (peak to peak) 40/1.6 mm/inch
Voice Coil Material Copper
Voice Coil Winding Depth 9/0.35 mm/inch
Number of layers 2
Kind of layer Inside/Outside
Top Plate Thickness 9/0.35 mm/inch
Cone Material No pressed pulp
Cone Design Curved
Surround Material Polycotton
Surround Design M - roll
Resonance frequency Fs 68 Hz
Mechanical factor Qms 4.2
Electrical factor Qes 0.25
Total factor Qts 0.24
BL factor BL 17.5 T - m
Effective Moving Mass Mms 36 gr
Equivalent Cas air load Vas 26 liters
Effective piston area Sd 0.035 m2
Max. linear excursion (mathematical) Xmax 2.5 mm
Voice - coil inductance @ 1kHz Le1k 1.3 mH
Half-space efficiency Eff 3.15 %
Overall Diameter 260/10.6 mm/inch
Bolt Circle Diameter 244.5/9.6 mm
Bolt Hole Diameter 5.5/0.2 mm/inch
SHIPPING INFORMATION
Net Weight 7.70/16.9 Kg/lbs
Shipping Weight 8.10/17.8 Kg/lbs
Note the Exact same Template, I've never seen 2 manufact. have identical specification templates word for word.
its quite clear you edited RCF's Parameters,but you left alot unchanged, I've never seen 2 drivers from different companies with such identical parameters.
And Lastly, to Top it off, Probably the most improtant Spec you did not alter properly was the Weight, oh gosh man.
Net Weight 6.70kgs is NOT 16.9lbs
AND
Shipping Weight 6.10kgs is NOT 17.8lbs
LMAO LMAO LMAO #owned
This has to be the worse epic pwnage in history
Ah man claim to be designing speakers
When he really copy and paste from another site yes and call it his
southside connections, yuh is ah piece of hogsh1t Laughing
View user's profile Send private message Visit poster's website
kurpal_v2
Tech posts: 1146
PostPosted: Thu Sep 18, 2008 7:52 pm
It is... I hear ah man does go away to "visit" jacob fuller 8 times a year...
But to this day, how the faq fuzz know RCF specs so good? Laughing
illumin@ti
Tech posts: 360
My 2NRide: Mitsubishi Lancer
PostPosted: Thu Sep 18, 2008 7:57 pm
cuzz fuzz izza baller yo ---- thas my taliban contact in central ---- keep it gangsta G Wink
(...Rovin...)
Tech posts: 3651
PostPosted: Thu Sep 18, 2008 8:07 pm
u rel like commess yes ..... Neutral
kurpal_v2
Tech posts: 1146
PostPosted: Thu Sep 18, 2008 8:39 pm
^^ Na pios just feeling down beti leave her so she bump a thread to make her feel better..
Tech posts: 4030
My 2NRide: Toyota
PostPosted: Thu Sep 18, 2008 9:22 pm
boom you find ah 13 socket yet? Neutral
kurpal_v2
Tech posts: 1146
PostPosted: Thu Sep 18, 2008 10:03 pm
^^ Nope stacy....
fuzz_174
Tech posts: 1040
My 2NRide: Ford Capri
PostPosted: Fri Sep 19, 2008 12:23 am
taliban contact you say n@ti?
kurpal_v2
Tech posts: 1146
PostPosted: Fri Sep 19, 2008 6:33 am
^ The man of te thread, my man.... How u find RCF specs so fast??
illumin@ti
Tech posts: 360
PostPosted: Fri Sep 19, 2008 8:14 am
But of course.... Laughing Laughing Laughing how goes it dude ,, long time
3stagevtec
Tech posts: 4473
My 2NRide: Suzuki Grand Vitara
PostPosted: Thu Apr 09, 2009 5:14 pm
it has returned!!
Lance
TriniTuner WHOoRE
Tech posts: 1380
PostPosted: Thu Apr 09, 2009 5:38 pm
this one still cracks me up,
Its EPIC
Dj_Bee
Tech posts: 324
PostPosted: Thu Apr 09, 2009 8:06 pm
Laughing Laughing
fuzz_174
Tech posts: 1040
PostPosted: Thu Apr 09, 2009 11:21 pm
this still around? lol
SR
Chief Cook & Instigator
Tech posts: 6585
PostPosted: Fri Apr 10, 2009 7:54 am
when trying to look make yourslef important google is you best friend in a technical thread
if it wasnt for google we may never had had soo many "experts" giving advice
Post new topic   Reply to topic   printer-friendly view    trinituner.com Forum Index -> Ole talk and more Ole talk All times are GMT - 4 Hours
Page 9 of 10
