But isn't 'tuning' reflashing? Will my car have permanently retarded IT (timing) afterwards?Polydor wrote:sr18 Primera wrote:The ecu disabled your boost control. You're stuck at wastegate boost ~7psi.
It did that because it was detecting lots of knock... get your car tuned!!!
^^^What
U sound quite convincing and logical.vin_ud wrote:its not permanent
u could go bak to the stock map if u dont like the tune
but i assure u
if u go ECUTEK.. you would have no complaints and be very impressed
get it tuned
What??
I think I will take ur advice...but any views on the fuel additives? Are u running additives and is ECUTEK tuned for premium (95RON)?
Who can do this for me?
Would it be better to leave the current tuning and use an octane boost additive to the fuel...? Would the ECU re-compensate and bring back up the boost?
Knight1 wrote:^6Get your car checked by a mechanic first.
or in my view, get your hands on some racing fuel (just this once).
Run it in your car, and see if the problem goes away. If the problem DOES go away, and only returns when you fill up with normal pump gas.....you have your problem.
That should be your first step.
Knight1 wrote:^^^An ECU reset doesn't change engine parameters...so I can't see why it would help.
In fact, if his car his knocking that badly that boost is dropping, resetting the ECU may make it even worse, as the ECU will lose the "learned" data of having gone into "high detonation mode/map".
All a reset will do is force the ignition advance multiplier (IAM) back down to 8....after which the ECU will try to learn/adapt to gas conditions again...attempting to reach 16.
You'll have two scenarios at this point to consider:
1) If the problem is that he got a "bad spot" of gas...then by the time the old gas is used up, and a fresh "better" gas (I use that term loosely) is put in, the ECU will correct itself in a few hours of driving, with boost returning to normal.
This could be the scenario depending on where you buy gas from. I bought Premium from Valpark gas station once..and my boost refused to cross 14.6 psi afterwards. Once that tank was done, and I continued buying near my workplace....boost levels returned to normal
So in short, an ECU reset is not really needed.
2) If the problem is a mechanical one (say faulty ignition etc), then an ECU reset will not help either.
Ok fellas, besides all of this reflashing and retuning talk
Check to see if any of the vacuum hoses on the intake manifold have split or severed, this could cause loss of boost pressure while stipp operating normally in vacuum, idling etc.
