Posted: Thu Oct 26, 2006 8:59 am Post subject: |
scosche efx also had a good line but i dont think electromania brings it any more
its easy to tell
just look at the thichness of the wire inside the insulation and check the flexibility of the cable
the more flexible it is most of the time the more strands the cable has |
pioneer punchin NOS
Joined: 18 Apr 2003 Tech posts: 4030 Location: Harmony|Chaos My 2NRide: Toyota
Posted: Thu Oct 26, 2006 9:39 pm Post subject: |
I've seen 4awg audiopipe same size as stinger and efx 8 awg  |
Sully Trying to catch PATCH AND VEGA
Posted: Thu Oct 26, 2006 10:14 pm Post subject: |
| Quote: |
hmm ... where do I get wire now? What do they bring now? |
ravestarfx 3NE 2NR for life
Joined: 23 May 2004 Tech posts: 232 Location: R&K IMPORTS LTD My 2NRide:
Posted: Fri Oct 27, 2006 1:23 am Post subject: |
u can also go SOUND QUEST wires n accessories
i will call u tomorow regarding pricing what is ur number
buy only genuine products
rcw imports - authorised sound quest dealer |
Posted: Fri Oct 27, 2006 10:13 am Post subject: |
| Quote: |
Nigel, isn't that the other brand of optical cable that was being sold by RadioShack online? Why didn't you just get rave to bring an optical cable in for you? |
Exonic 3NE 2NR Power Seller
Joined: 21 Apr 2003 Tech posts: 679 Location: Marabella, Trinidad and Tobago My 2NRide:
Posted: Fri Oct 27, 2006 10:23 am Post subject: |
The price is $25.00 per ft/ $75.00 per yard |
nigel1977 punchin NOS
My 2NRide: Toyota Liteace
Posted: Fri Oct 27, 2006 10:59 am Post subject: |
| Sully wrote: | | Quote: |
cus it wasnt on any of the gazillion catalogs he had...  |
(...Rovin...) 3NE 2NR Power Seller
Joined: 21 Jan 2006 Tech posts: 3651 Location: Chaguanas My 2NRide:
Posted: Wed Feb 27, 2008 11:59 am Post subject: |
Big 3 with 4g or 0g wire ? ...
was discussing this & wanted to get more views
would it be a credible difference using 0g instead of 4g wire to do big 3 ???
is 0g overkill because d distance is only about 4ft from alt to batt or will depnd on how powerful ur amps are ??? ........  |
southside connections Shifting into 6th
Posted: Wed Feb 27, 2008 12:04 pm Post subject: |
nah
my car has 2 runs of 4awg for each cable replaced
i have to just replace the engine grounds and that's it  |
Lance TriniTuner WHOoRE
Joined: 21 Jun 2005 Tech posts: 1380 Location: Arima My 2NRide:
Posted: Wed Feb 27, 2008 12:06 pm Post subject: |
| MR. ROVIN wrote: |
is 0g overkill because d distance is only about 4ft from alt to batt |
This is my view also,
I believe Guage Selection is a function of, Current Draw and distance, for Big3's 4Guage is enough in MOST Daily cases.
especially in trinidad when everybody want to run stock alts, even the big ones in carshows. |
pioneer punchin NOS
Posted: Wed Feb 27, 2008 12:15 pm Post subject: |
| Exonic wrote: |
Thaz ah real good price for 0 |
Posted: Wed Feb 27, 2008 12:17 pm Post subject: |
| ^watch d date that was posted eh since world price on copper wire products keep going up often - stinger is around $80-85+\yd now other brands even more $.... |
Posted: Wed Feb 27, 2008 12:23 pm Post subject: |
| yeah, if the price of copper is on the increase everyday, and you see prices remaining the same, look out, its either you getting short changed on your wire, or thats a mighty fine Company whose willing to take a big hit for its customers. |
kurpal_v2 Riding on 16's
Joined: 28 Dec 2007 Tech posts: 1146 Location: shaking down my bhaji tin My 2NRide:
Posted: Fri Jul 03, 2009 12:02 pm Post subject: |
| Lance wrote: | | MR. ROVIN wrote: |
Ok now I have to do my big3 but Ive come across some "problems" so to say.
I wanna use 0awg to eliminate any possible bottlenecks within the charging system but Ive read some stuff like this
| Quote: |
The biggest problem with output studs melting is actually the connector that you use. 99% of all 1/0 crimp-on cable ends have a 8mm hole in them. When you use a 8mm hole on a 6mm stud, the contact surface area is GREATLY reduced. This creates a restriction in current flow, and subsequently a hot spot that can burn up. |
And this is comming from reliable ppl.
So the question that comes to my mind is should I get 4awg wire? I dont want to cause I have a lot of 0awg sitting around.
I have a stock alt btw.. |
Posted: Fri Jul 03, 2009 12:17 pm Post subject: |
might as well put d 0 so u wont have to worry about upgrading it in d future
let me ask a ? here :
for serious SPL vehicles , is doing a even bigger wire from d ho alt to engine batt from 0g to a 2\0 or 3\0 going to make even any slight voltage or current transfer improvements , even a 0.1 or 0.2v difference ???? ....  |
Posted: Fri Jul 03, 2009 12:38 pm Post subject: |
Depending on current draw and the battery bank you suppling I guess.
But most fart box applications Ive seen they bypass the factory batt and go straight to the back battery bank with multiple runs of wire. |
Posted: Fri Jul 03, 2009 12:51 pm Post subject: |
| as for covering the ground points for rusting,i use spray silicone,works well so far |
Posted: Fri Jul 03, 2009 1:16 pm Post subject: |
^ How often do you use 0awg on stock alternators?
How often has there been a failure? |
Posted: Fri Jul 03, 2009 1:31 pm Post subject: |
| i never said i used 0awg on alternators^^^ |
theblitz Chronic TriniTuner
Joined: 24 Jun 2007 Tech posts: 624 Location: South Trinidad My 2NRide: Toyota Corolla
Posted: Fri Jul 03, 2009 1:44 pm Post subject: |
kurpal_v2, what do you mean by failure? of what?
If you using zero gauge and have a problem with the small hole on the crimp end then get a drill, lock the end in a table vise and bore it out. I did this many times. |
