| Hook wrote: |
| I think it's two problems he's addressing there
wrt the coolant temperature sensor, don't bridge it...unless u have a wideband O2 sensor to properly monitor your AFR, u risk running very lean by doing that and it could cost u an engine. BTW, did u reset the ECU after u changed the sensor? secondly, the fan switch only turns the fan on when the wire connection to it is broken, so if the fan is on all the time, u need to check the fan switch wire and make sure it's nor broken before u start interfering with the switch itself |
