box lancer diff: "welding slugs"
trinituner.com -> MITSUBISHI
#1: box lancer diff: "welding slugs" Author: carbon PostPosted: Sat Jun 27, 2009 6:08 pm
hey tuners.....just trying 2 find out as much info as possible on "welding slugs" on the stock diff rather than replacing it, 4 a box lancer...tnk u
#2: Re: box lancer diff: "welding slugs" Author: SanctifierLocation: Good question! PostPosted: Sun Jun 28, 2009 8:19 am
carbon wrote:
..."welding slugs" on the stock diff...
What are "slugs"?...
If it's suspension mounting points, IMHO DON'T weld on cast-iron diff-housing. It will crack.
If using axle-housing tubes instead, mount in jig BEFORE welding to prevent warping... OR... keep axles & diff installed (and keep cooled) to stiffen diff-housing... (not as good. BTW oil burns!)
OR... use different suspension links instead (eg. "equal 4-link" & panard-rod?)
... STRONGER and more reliable setup than welding on cast-iron housing IMHO.
My $0.02¢
#3:  Author: venumLocation: San Fernando PostPosted: Sun Jun 28, 2009 8:07 pm
^ ^ ^ when the next semester starting Question
Cuz u just lost me
I need to go to school for that one
*off to howstuffworks.com*
#4:  Author: carbon PostPosted: Sun Jun 28, 2009 8:40 pm
tnx......still nt too clear..if u cud upload sum pics or a vid...will b greatly appreciated..
#5: Re: box lancer diff: "welding slugs" Author: gallantpanLocation: San Fernando PostPosted: Wed Jul 01, 2009 9:45 pm
"slugs" <i know not what you mean> & and you can weld on cast iron with the correct procedure.
#6:  Author: SanctifierLocation: Good question! PostPosted: Thu Jul 02, 2009 6:47 am
gallantpan wrote:
...you can weld on cast iron with the correct procedure...
^ ^ ^ Yup... but how many 2nrs have access to (or can afford) the correct welding proceedure?
Incorrect procedure...
Sanctifier wrote:
EPOXY in yuh tail, when the WELDING DIDN'T WORK!
WE GO TRY WELDING DE NEX SIDE TOO!... (Lower right on Balance-shaft housing...)
Main-bearing Girdle repair... More "Professional Tuner" engineering at its BEST! Rolling Eyes
Correct procedure...
Sanctifier wrote:
* It's impossible to weld cast iron successfully without specialist equipment, using special welding rod
... and the piece MUST be pre-heated (in a controlled environment) BEFORE & DURING welding...
(...and should be COOLED in a CONTROLLED manner!)
Another way to repair a damaged cast-iron block (for N/A or Diesel applications ONLY) is to use
the "Metalock" method...
Cut out the cracked area, cut a steel plug to fit... drill a surrounding "ring" of small holes...
screw in Nickel plugs... surface grind plug edges.
IMHO I would NEVER use any welded block for a high-boost turbo engine.
My $0.02¢
The REAL Cast-iron Repair Experts wrote:
Reference... Successful methods of cast-iron repair...
http://www.metalockint.org.uk/news/Metalock_UK_web.pdf
http://www.r-f.com/superior.htm
http://www.patentstorm.us/patents/7047612-description.html
Link--> CAVEAT EMPTOR! a.k.a. 4G63 BOGUS work... & TORQUE PLATES.
Their $0.02¢
venum wrote:
^ ^ ^ when the next semester starting Question ...
Howzat venum?... Wink ...Lecture 2 below... Laughing
#7:  Author: SanctifierLocation: Good question! PostPosted: Thu Jul 02, 2009 7:32 am
Read---> Link--> Welding on Axle Tubes - TTORA Forum.
Link--> SOA – Axle Housing welding and possible problems (warpage ...etc.)
"Google" works wonders... Try... "axle housing welding"... etc. etc. Wink
Also "search" Hot Rod mag, Car Craft mag etc. etc. for more articles.
Whey yuh venum? Laughing
#8:  Author: gallantpanLocation: San Fernando PostPosted: Thu Jul 02, 2009 11:27 pm
what is this -an i know -you know competion? ah want to no wat he mean by "slugs" all them diff engine pics & links aint helpin him weld he diff.. #Splat
#9:  Author: SanctifierLocation: Good question! PostPosted: Fri Jul 03, 2009 9:12 am
gallantpan wrote:
...all them diff engine pics & links aint helpin him weld he diff...
Obviously the post with pix shows what happens when bad cast-iron weldments fail. Rolling Eyes
BTW did you read the last two links?... Axles... Axles... Axles.
#10:  Author: gallantpanLocation: San Fernando PostPosted: Fri Jul 03, 2009 10:13 pm
#laughpoke
