WTK Bseries harnesses urgently
trinituner.com -> HONDA
#1: WTK Bseries harnesses urgently Author: dok_tec PostPosted: Thu Jun 25, 2009 5:28 pm
want to know if a b16a harness and b18c1 harness are similar . also i want to get some a pinout diagram for a b18c sirg ecu as well as a p28 obd1 pin out thanks
#2:  Author: JD...... PostPosted: Thu Jun 25, 2009 6:12 pm
cant help but i have conversion harnesses if you need
#3:  Author: red_dragonLocation: HUNTING FOR KINDAY PostPosted: Thu Jun 25, 2009 6:12 pm
b16a harness and b18c .. some parts .. the parts for the dual butterfly only the b18 has it
for pin outs check
http://www.phearable.net/tech/
unless u wanna use the b18c block and b16a head then the b16a harness would work
#4:  Author: Hirotoshi PostPosted: Fri Jun 26, 2009 10:51 am
the b18c intake manifold is a two piece design with a sandwich butterfly valves, also it has a knock sensor. if you choose to use a p28 ecu(us spec),you will need a conversion harness. Cool
#5:  Author: JD...... PostPosted: Mon Jun 29, 2009 10:29 am
check you pm inbox
