Problem....!!!!!
trinituner.com -> TECH STUFF
#1: Problem....!!!!! Author: centralized(m) PostPosted: Tue Jun 23, 2009 7:57 pm
Alright...... simply i have a problem.....when the a/c is on and i mash down the car makes a strange noise. that noise sounds like the belts squealing. wen dis is happening the car feels like it sticking in gear....like if the belts or gear stops spining...well it feels so..i does lift my foot of the gas wen it happens and it stops.... i mash down wen in park but doesnt get that kind of response.... so wat is happening????
#2:  Author: HookLocation: Wondering why that fag is so obsessed with getting access to my facebook. PostPosted: Tue Jun 23, 2009 8:30 pm
check the tension on your accessory belts (A/C, P/S, alternator etc)
#3: belts Author: slow323Location: pos, maraval PostPosted: Tue Jun 23, 2009 10:48 pm
X2 also inspect to see if they need changing
#4:  Author: necktoLocation: Engine Room PostPosted: Wed Jun 24, 2009 2:20 pm
had this similar problem
was faulty belts
i suggest changing out all ur belts esp the timing belt if ur engine is belt drive
it may not be the faulty belt but better safer than sorry i almost mash up my engine due to timing belt burst
it was other faulty belt but it cause extra stress on timing belt
#5:  Author: centralized(m) PostPosted: Wed Jun 24, 2009 6:50 pm
but the wierd ting is that i changed all belts except timing belt las year and got the tension re-checked afterwards also.....hmmmmm....but as turboboy told me in d post in mitusbishi that it can be the compressor going bad or the compressor pully bearing going bad...take a read of wat he said fellas and see if u agree...i kinda goin with wat he sugessting...!!!!!!
#6:  Author: bluesteel29Location: P.O.S PostPosted: Wed Jun 24, 2009 6:52 pm
the clutch in the a/c compressor iz sticking
#7:  Author: centralized(m) PostPosted: Wed Jun 24, 2009 7:17 pm
wen u say sticking wat u mean that the compressor cylce is either remaining on or off.....i dont quite understand
#8:  Author: bluesteel29Location: P.O.S PostPosted: Wed Jun 24, 2009 10:46 pm
u gettin cold breeze??
is it a really loud squealing sound??
did u check to see if the a/c belt is moving?
an when u mash the sound will go away???
#9:  Author: centralized(m) PostPosted: Wed Jun 24, 2009 11:01 pm
1. reallllllllll cold breeze
2.so loud ppl does pull to d side and ting
3. moving how???
4.wen i mash is wen d sound happens if i let go d gas it will stop, but doesnt happen all all d time so...like wen it ready!!!!
#10:  Author: bluesteel29Location: P.O.S PostPosted: Wed Jun 24, 2009 11:16 pm
when it makin the noise it iz still be cold??
u seein the belt spinning on the compressor as normal?
#11:  Author: centralized(m) PostPosted: Wed Jun 24, 2009 11:41 pm
nah like d a/c doesnt be cold as it is
2.yea d belt spining normal
#12:  Author: bluesteel29Location: P.O.S PostPosted: Wed Jun 24, 2009 11:43 pm
wat that guy said iz correct.....a part in the compressor has gone bad....find out the cost to rebuild/bamboo for nex comp.
#13:  Author: THE_FUGITIVESLocation: >l(()))'> PostPosted: Thu Jun 25, 2009 12:04 am
Take out and carry by Ac compressor Specialist
#14:  Author: mossmanLocation: Trincity PostPosted: Thu Jun 25, 2009 11:35 am
compressor problem... good luck
#15:  Author: dregz PostPosted: Fri Jun 26, 2009 7:08 pm
is it a profound knocking sound?
because i realize this was happening to a friends car and it turned out to b the compressor. good luck man.
#16:  Author: larnelle salandyLocation: diego PostPosted: Tue Jun 30, 2009 11:51 pm
compressor
#17:  Author: necktoLocation: Engine Room PostPosted: Wed Jul 01, 2009 10:34 am
this sort out yet?
what was the prob?
#18:  Author: centralized(m) PostPosted: Wed Jul 01, 2009 7:26 pm
nah aint sort out yet...will get it by weekend though
#19:  Author: brams112Location: trinidad PostPosted: Wed Jul 01, 2009 8:47 pm
you can also check on the crankshaft pulley,some carry a buffer built in the pulley for vibration dampning,if it is bad it also makes a squeaking sound.
#20:  Author: Sheriff!Location: Some Where Out There Shouting "All'uh Buy Zorce From Meh Na" PostPosted: Wed Jul 01, 2009 10:15 pm
compressor
