Help:Transmission Problem
trinituner.com -> HONDA
#1: Help:Transmission Problem Author: fearsaga15Location: St.Joseph PostPosted: Mon Jun 22, 2009 11:12 am
None of my gears working, not even reverse Confused . This happened just like that. When I move the shifter to drive and i try to accelerate, the engine jus revs. same thing with reverse gear.
Does this mean the transmission gone? or wht else could it be?
How much so I looking at to get this fixed? or cud it even be repaired?
It's an es5 model civic, d16w7 engine.
Thanks.
#2:  Author: halfdef PostPosted: Mon Jun 22, 2009 6:52 pm
cvt?
#3:  Author: fearsaga15Location: St.Joseph PostPosted: Mon Jun 22, 2009 7:21 pm
not cvt
#4:  Author: praiseLocation: Port of Spain PostPosted: Mon Jun 22, 2009 7:33 pm
If you are not even getting a jerk when you change gears, your torque convertor needs replacement.
#5:  Author: fearsaga15Location: St.Joseph PostPosted: Mon Jun 22, 2009 7:44 pm
that's it?
#6:  Author: reiXmannLocation: 1coat PostPosted: Mon Jun 22, 2009 7:54 pm
fearsaga15, it could be many things...take it to a qualified mechanic and have him check it please #Fade in
one in el socorro: jason 728-5644...call early
#7:  Author: DamienLocation: Skinning PostPosted: Mon Jun 22, 2009 7:58 pm
Jack up the car and check if you damage anything on the underneath and check oil and just go by a qualified mechanic
#8:  Author: fearsaga15Location: St.Joseph PostPosted: Mon Jun 22, 2009 8:01 pm
ireiXmann, passed by jason after work. he said bring it b4 12 tonite or 6 in d mornin.
jus tryin to figure out if i lookin at trans replacement
#9:  Author: fearsaga15Location: St.Joseph PostPosted: Mon Jun 22, 2009 8:04 pm
thanks for d advice tho ppl
#10:  Author: fearsaga15Location: St.Joseph PostPosted: Mon Jun 22, 2009 8:26 pm
Damien,everything underneath looks fine, oil is good
when i rev tho, i hearin a loud hummin noise
#11:  Author: praiseLocation: Port of Spain PostPosted: Mon Jun 22, 2009 8:50 pm
Bro a non cvt transmission do not go just like that. It will start to hard shift and slip first. A torque convertor strips just like that. Remove one of the ATF hose from the rradiator and start engine. If no oil is pumping out your convertor is strip.
#12:  Author: fearsaga15Location: St.Joseph PostPosted: Mon Jun 22, 2009 8:55 pm
praise, good to know thanks
#13:  Author: DamienLocation: Skinning PostPosted: Mon Jun 22, 2009 9:20 pm
best bet is to get it checked out by a professional parts kinda real expensive for this model and it hard to get foreign used to
#14:  Author: SUPAstarrLocation: Her name is Isabel and she gettin an H PostPosted: Tue Jun 23, 2009 8:05 am
thats the end of it, exactly the same happened to my last tranny on the hatch, was in the airport, tried to go in to park car just revved, not even rverse
