front stage help
trinituner.com -> I.C.E.
#1: front stage help Author: threeplumes PostPosted: Sun Jun 21, 2009 4:08 pm
would it be better to use a cheap component set or buy a good priced coaxial set $500 to $700.
#2:  Author: evolution7tt PostPosted: Sun Jun 21, 2009 5:56 pm
Check the forums for a good used component set at the price you're looking at. Or check Exonic.
#3:  Author: X_FactorLocation: St. Augustine PostPosted: Sun Jun 21, 2009 7:49 pm
state the brands and model of choice...u might be better advised
#4:  Author: audiopipe PostPosted: Sun Jun 21, 2009 8:30 pm
check out my post
i have a set of q line an reference components for $2400 excellent condition
#5:  Author: threeplumes PostPosted: Sun Jun 21, 2009 8:43 pm
not sure yet......what type of coaxials can i get for $700. but on the component side,i could get MB QUART formula series, powerbass c6..........
#6:  Author: fuzz_174Location: Eastern Afghanistan PostPosted: Sun Jun 21, 2009 9:18 pm
I have a brand new pair of Boston components, comes with crossovers as well $900
http://forums.trinituner.com/forums/viewtopic.php?t=252663
#7:  Author: threeplumes PostPosted: Mon Jun 22, 2009 5:02 pm
will think about it....but what about the coaxials ppl
#8:  Author: slow323Location: pos, maraval PostPosted: Mon Jun 22, 2009 5:16 pm
good coaxials would have the passives built on i mean you would see them by the terminals
but i myself have been looking on the forums and it really looking like you go come out better price wise with components the good hi quality coaxials are expensive
#9:  Author: Soundstream_626Location: san juan PostPosted: Mon Jun 22, 2009 7:13 pm
comps have more flexibility
coaxials usually only have 6db filters and the only coax i ever saw with a lpf for the mid built onto the unit is the alpine type r coaxes
there are passives that can masquerade as coaxes with the tweeter being able to screw onto the middle of the mid but
i would say buy a pr of comps ... ud get better crossover filtering as well as level adjustment and even tweeter protection on some models
fuzz have a bess deal there ... take it and run bostons are great
#10:  Author: ExonicLocation: Marabella, Trinidad and Tobago PostPosted: Mon Jun 22, 2009 7:49 pm
CDT Audio, Alpine Type S, R, X, Bravox, DLS and others.
Component sand coaxials
734-5350
Please call to set up an appointment to view.
#11:  Author: Aimar PostPosted: Mon Jun 22, 2009 9:59 pm
At that price range you will be better of with a set of entry line comps.
I think richepooh has a set of boston SL comps for $800 (used), but at that price you can't go wrong Exclamation
Even the entry line Boston's that Fuzz has will be well worth your while.
#12:  Author: silent_riotLocation: Gone digital PostPosted: Tue Jun 23, 2009 10:35 am
Comps for flexibility in installation. But once you install them okay, coaxials sound good too.
#13:  Author: (...Rovin...)Location: Chaguanas PostPosted: Tue Jun 23, 2009 10:52 am
i prefer comps ...
#14:  Author: kurpal_v2Location: shaking down my bhaji tin PostPosted: Tue Jun 23, 2009 8:53 pm
X2.. Ive yet to be failed by my dls 126. But WRT staging, compts rock!!.
#15:  Author: SR PostPosted: Tue Jun 23, 2009 9:01 pm
DLS B6 components $675
Woofer size 16,5 cm / 6,5"
Power handling capacity 50 W RMS / 80 W max / 150 W peak power
Tweeter 16 mm / 0,63"
Frequency range 50-18.000 Hz
Crossover point (Hz) 6000 Hz
Sensitivity 91 dB (1W/1m)
Outer diameter of woofer 165 mm / 6,5"
Magnet size 80 mm / 3,15"
Crossover Cable filter with 12/12 dB slope (LP/HP)
Size of filter box 60 x 30 x 30 mm (2,36 x 1,25 x 1,25")
Mounting depth 63 mm / 2,48"
Mounting hole 146 mm / 5,75"
Impedance 4 ohm
http://www.dls.se/en/car/prod.html?produkt=en_50
#16:  Author: SR PostPosted: Tue Jun 23, 2009 9:04 pm
DLS 226 coaxial $530
Tweeter 16 mm (0,63")
Crossover Cable filter with 6/12 dB slope (HP/LP)
Woofer size 16,5 cm (6,5")
Frequency range 50 - 20.000 Hz
Sensitivity 92 dB (1W/1m)
Outer diameter of woofer 165 mm (6,5")
Magnet size 80 mm (3,15")
Mounting depth 52 mm ( 2")
Mounting hole 145 mm (5,7")
Impedance 4 ohm
http://www.dls.se/en/car/prod.html?produkt=en_84
#17:  Author: threeplumes PostPosted: Tue Jun 23, 2009 9:23 pm
Impedance 4 ohm
i feel i going with this... Cool
#18:  Author: insane37 PostPosted: Tue Jun 23, 2009 11:12 pm
dats d nice set there.
the comps fuzz has are really good and thats a real bess price too.
