#1: wtk about wire setup Author: kevinsonny, Posted: Wed Jun 17, 2009 7:48 pm hey guys i have a distribution block hooked up for two amp rite, i want to know if i still need the fuse holder that people does put by the battery?
#2: Author: madman.devin, Posted: Wed Jun 17, 2009 7:51 pm yea U still need one under 18 " from the battery !! lol
#3: Author: theblitz, Location: South TrinidadPosted: Thu Jun 18, 2009 6:47 pm yes you still are strongly advised to use a fuse capable of passing the max current of everything powered off that cable w/o going much over. This fuse is a safety measure against the event that a short circuit occurs. Many vehicular fires are caused by improper electrical wiring and fusing.
And know the capabilities of your cables... do not attempt to do something like use a 200A fuse on a 4AWG line
#4: Author: kevinsonny, Posted: Tue Jun 23, 2009 5:05 pm what about if i wanna run a next battery in the back? do i still need the fuse and if yes what current rating?
#5: Author: theblitz, Location: South TrinidadPosted: Tue Jun 23, 2009 6:43 pm you need a fuse near each battery on the +ve wire.
#6: Author: kevinsonny, Posted: Wed Jun 24, 2009 5:58 pm ok thanks guys
