#1: WTK- lowering a new model civic Author: parts pro, Location: southPosted: Sat Jun 13, 2009 4:48 pm I have a 2006 civic, with the factory body kit , i've installed some 18" rim and tyres however the back of the car is significantly higher than the front. If i were to lower the back only will this cause the vehicle's alignment to be off?
#2: Author: phaze, Posted: Sun Jun 14, 2009 9:26 am lowering the back alone shouldnt cause the alignment to be off. wat would cause out of alignment is how low u drop the back..
#3: Author: phaze, Posted: Sun Jun 14, 2009 9:27 am lowering the back alone shouldnt cause the alignment to be off. wat would cause out of alignment is how low u drop the back..
#4: Author: Damien, Location: SkinningPosted: Sun Jun 14, 2009 12:30 pm it will affect the camber of the back
#5: Author: bluesteel29, Location: P.O.SPosted: Sun Jun 14, 2009 4:46 pm when lowering ur vehicle take into consideration the kinda bad roads trindad have....
#6: Author: roseman, Location: Somewhere far far far awayPosted: Thu Jun 18, 2009 8:37 pm i have the 2001 model, and it's like 3 - 4 inches off the ground. its the worst with the trini roads.
if u drop the back u'll end up with a negative camber.
right now im looking to raise it back
#7: Author: nick1323, Posted: Thu Jun 18, 2009 8:43 pm it you dont want any problems use drop springs, but the ones i used on my 2007 civic did not lower it at all, so i used another spring for another car and then my bearings went bad, then the camber in the back was off rel bad, had to buy 20" tires every two months. u will need a camber kit.
#8: Author: parts pro, Location: southPosted: Fri Jun 19, 2009 3:35 pm thanks for the info fellas, think i may jus order the type r wing and give it an integra appearance.
#9: Author: roseman, Location: Somewhere far far far awayPosted: Mon Jun 22, 2009 7:04 pm at least u can get 20's. im rolling on 19's.
