W.T.K super in a peugeot
trinituner.com -> TECH STUFF
#1: W.T.K super in a peugeot Author: Honda_RoachLocation: Searching for a new transmission or gearbox! PostPosted: Sun Jun 07, 2009 8:04 am
anyone running super unleaded in there Peugeot? any disadvantages or loss of performance observed?
#2:  Author: dregz PostPosted: Fri Jun 26, 2009 8:13 pm
i running super
no problems
#3:  Author: Honda_RoachLocation: Searching for a new transmission or gearbox! PostPosted: Sat Jun 27, 2009 10:40 am
thx man
#4:  Author: christopherwilliams2Location: Arima PostPosted: Sat Jun 27, 2009 10:54 am
i'm running on super and it is absolutely no problem...verified by 3 different mechanics...
#5:  Author: slimshiney PostPosted: Sat Jun 27, 2009 11:35 am
once the engine compression is below 10.1.. you are safe with super...
#6:  Author: dregz PostPosted: Sat Jun 27, 2009 1:32 pm
why is that thou?
#7:  Author: vansLocation: where ever d $ is PostPosted: Sat Jun 27, 2009 4:28 pm
^^^ x2
#8:  Author: christopherwilliams2Location: Arima PostPosted: Sat Jun 27, 2009 5:30 pm
and how do you know or check this?
#9:  Author: slimshiney PostPosted: Sun Jun 28, 2009 2:51 pm
correct me if i'm wrong...but our local super carries a octane rating of 87...and it is recommended for vehicles under the 10.1 ratio...as for the compression ratio...u can check your owners manual..or do a compression test...long story short....at the end of the day...i still use my discretion...try the super..listen for for the knocking...if not....use it add a treatment monthly...my advice(be mindful there might be a slight drop if any @ all in accelaration)....jus my lil 2cents..
#10:  Author: dregz PostPosted: Sun Jun 28, 2009 3:48 pm
i havent had any problems, and wel i use ah redline every so often.
buh i hav ah trick that some ppl condem: i throw in ah few naphthalene balls in d gas tank, about 2-3 for the month and i dont let tha tank run under 1/4. at months end i run d tank low and then refill, when i add redline i do not add d naphta.
#11:  Author: christopherwilliams2Location: Arima PostPosted: Sun Jun 28, 2009 4:37 pm
what!!!! ^^^
#12:  Author: Knight1Location: On terra firma PostPosted: Sun Jun 28, 2009 6:31 pm
92 RON. Regular (fuh dem ol' boat) *used* to be 85-87.
You does buy gas by d wharf or something?
#13:  Author: frontier PostPosted: Mon Jun 29, 2009 12:53 pm
you can use super comfortably without any problems
#14:  Author: slimshiney PostPosted: Mon Jun 29, 2009 10:08 pm
i asked for the correction.....tanx....
#15:  Author: christopherwilliams2Location: Arima PostPosted: Tue Jun 30, 2009 8:38 am
is true....
our super octane is at 92 and premium at 95 and from my 306/406 owner's manual it says that the minimum octane required is 91 so our Super Gas is all fine!
#16:  Author: GEAR_HEAD PostPosted: Tue Jun 30, 2009 9:03 am
remember there is a difference between RON and MON....anyone care to explain Question
