ac problem
trinituner.com -> TECH STUFF
#1: ac problem Author: dtpLocation: trinidad PostPosted: Tue Jun 02, 2009 1:01 pm
hi got a ga15de
and when the car running it does cut off when ac on
other problem d water does disappear from the radiator i ent no what goin on
d last time i put it on it was causing over heating
so i lost with that problem
#2:  Author: oxidation PostPosted: Tue Jun 02, 2009 1:05 pm
when you say running you mean while in traffic or while driving like 20 km etc
does your car have a leak like a radiator hose leaking etc
you have a ga15de --- in what vehicle
is the step up unit working etc
#3:  Author: HookLocation: Wondering why that fag is so obsessed with getting access to my facebook. PostPosted: Tue Jun 02, 2009 2:31 pm
I was now gonna ask about the step-up/idle-up unit...make sure it's operational and make sure there are no vacuum leaks
for the radiator, check the cap, hoses and the rad itself for leaks
#4:  Author: dtpLocation: trinidad PostPosted: Fri Jun 05, 2009 10:15 am
only when i using d ac the water does disappear no leaks their
yea when i drivin slow i never try it when i doing 50km so
i got check de step-up/idle-up unit
only 2 time this happen to and i never use d ac after that sheit
#5:  Author: HookLocation: Wondering why that fag is so obsessed with getting access to my facebook. PostPosted: Fri Jun 05, 2009 10:32 am
Confused
I don't understand the connection between a/c and the radiator
#6:  Author: dtpLocation: trinidad PostPosted: Fri Jun 05, 2009 2:28 pm
serious it does happen when d ac come on temperature goes up
#7:  Author: HookLocation: Wondering why that fag is so obsessed with getting access to my facebook. PostPosted: Fri Jun 05, 2009 3:20 pm
so does it overheat when the a/c is on?
also, does the radiator fan come one even tho the a/c is on?
#8:  Author: dtpLocation: trinidad PostPosted: Fri Jun 05, 2009 4:54 pm
yea it comes on when ac is on
normal driving my temperature never pass 1/4 when ac goes on all type of madness takes place
#9:  Author: axeLocation: central PostPosted: Fri Jun 05, 2009 5:06 pm
cylinder head gasket gone hoss...im sure
#10:  Author: HookLocation: Wondering why that fag is so obsessed with getting access to my facebook. PostPosted: Sat Jun 06, 2009 8:54 am
u really not describing anything to me there dude...clearly u don't want any help....I gone
g'luck with ur problem
#11: gasket Author: slow323Location: pos, maraval PostPosted: Sat Jun 06, 2009 1:04 pm
X2 radiator water going, yeah it would be that
#12:  Author: HookLocation: Wondering why that fag is so obsessed with getting access to my facebook. PostPosted: Sun Jun 07, 2009 1:22 am
lol the solution might be much cheaper and less labour intensive than changing a head gasket inno
did u inspect your entire cooling system (hoses, water pump, thermostat housing, end caps and radiator) for leaks?
#13:  Author: brams112Location: trinidad PostPosted: Wed Jun 10, 2009 10:01 pm
check on fan belt,if the cylinder head gasket blew there will be water in the engine oil,it will get the oil white,the radiator will have oil in and around the top of the cover,as hook is saying,,, inspect the entire system while engine is running with the ac on,good advise he is giving Wink
#14: Re: gasket Author: M-Tech PostPosted: Sat Jun 20, 2009 10:50 am
Not necessarily the cyl head gasket if there is no water loss at all when the A/C is off. It does not have to be so bad.
If the A/C fan is not working or the system is building too much pressure due to an old dryer bottle or bad thermostat etc, it would put additional force on the engine and cause overheating and the reservoir bottle would expel water so you'd loose water.
Obviously if the engine overheats considerably or repeatedly you will damage your cylinder head gasket sometimes so slight your car would seem to work like normal under light loads. So check it properly in steps and and quickly because it can cost you an entire engine.
If you observe what brams112 said with water and oil mixing or if you start your car with the engine cold and radiator cover open and you see a lot of bubbles/froth or water jumping out, or a miss on the idle, then you'd know if you got a blown gasket as well. You can start your engine rebuild and ensure that what caused your overheating is resolved.
#15:  Author: D@rkChildLocation: Either down south or up north, sumtimes in central PostPosted: Sat Jun 20, 2009 9:42 pm
i having the same problem right now with water from disappearing from the radiator, but M-Tech said the water going to the reservoir bottle and being expelled, waiting to get a thermostat for the car to see if it gone bad
#16:  Author: vipervega PostPosted: Sun Jun 21, 2009 3:24 pm
had this EXACT problem alr but it turned out to be a bad thermostat
#17:  Author: dtpLocation: trinidad PostPosted: Tue Jun 23, 2009 2:20 pm
since the starting of the year i never added water to my radiator the water dont run out or leak
only last year when i turn the ac on the water disappear after that i never use it again
cyl head gasket good have no other problems with engine only when ac turns on
the water disappear happened 2 time to me last year after i never turn it back on
#18:  Author: necktoLocation: Engine Room PostPosted: Wed Jun 24, 2009 2:21 pm
thermostat
and idle unit
