Tools Used I.C.E ...
Goto page Previous  1, 2, 3, 4, 5, 6 ... 13, 14, 15  Next  :| |:
trinituner.com -> I.C.E.
#81:  Author: loudsound PostPosted: Fri May 02, 2008 12:10 am
pioneer wrote:
Kool thanks...any particular model #?
jed sorry 4 replyin late buh i hav my saw so long it doe hav d model anymore lol...all i can c it is 2.4 HP
#82:  Author: (...Rovin...)Location: Chaguanas PostPosted: Fri May 02, 2008 12:21 am
^^^those r d ol days when they used to rate them by HP & not amps
pioneer wrote:
Then i put in the Irwin 40T, and damnnn Shocked ...no effort at all...you just have to guide the saw.
The laser is useless really, unless
Other than that i'm happy with it, it did what i wanted it to do and was accurate.
good review & well thats pretty much what i said if u read back earlier in this thread ... Wink
#83:  Author: pioneerLocation: Harmony|Chaos PostPosted: Sun May 18, 2008 9:17 pm
Hey jus an update...i built this box using my B&D circ saw...
I plan to make another one, i'll get build pics from that one...gonna be sealed
Home made flared 3" PVC ports Laughing
Whipped out the porter cable orbital sander and rounded the edges so it won't tear the carpet - no i don't have a router so i used a sander.
I installed the ports after i carpetted, hence i got contact cement onto the carpet which looks messy, any idea how to get it off?
I might sell this box as it's tooo huge, can't fit a cooler Crying or Very sad
#84:  Author: (...Rovin...)Location: Chaguanas PostPosted: Sun May 18, 2008 10:23 pm
coulda make a new thread
need some full shots so we can see d whole box but not bad at all ...
#85:  Author: pioneerLocation: Harmony|Chaos PostPosted: Sun May 18, 2008 11:04 pm
Dunno if this one would help...
The wall you're seeing is actually the bottom of the box...hence the carpet line...ended up facing dem up cuz i find they were too close too the tailgate...
#86:  Author: (...Rovin...)Location: Chaguanas PostPosted: Sun May 18, 2008 11:24 pm
separate or single chamber ?
thats in d xtrail right - so now how far its from d trunk lid .... coulda counter sink d sub for a much neater look ... Mr. Green
#87:  Author: pioneerLocation: Harmony|Chaos PostPosted: Mon May 19, 2008 12:57 am
didnt really care to countersink...seperate chamber
#88:  Author: ChineyLocation: Maracas,St.Joseph PostPosted: Mon May 19, 2008 1:32 am
well done pios!!
well done.... Razz
#89:  Author: pioneerLocation: Harmony|Chaos PostPosted: Fri May 23, 2008 8:28 pm
Back to tools, what's a good inexpensive router i can buy?...i fed up use jig to cut circles
#90:  Author: X_FactorLocation: St. Augustine PostPosted: Sat May 24, 2008 12:24 am
how u made the flare ports?
#91:  Author: pioneerLocation: Harmony|Chaos PostPosted: Sat May 24, 2008 12:31 am
Well i had a 3" precision port...i need two so i decided not to use it...
So i heated the PVC over a stove and push it onto de inner flare from the PP...held it there till it got a lil cool and started to harden again
Then sand it down n paint it cuz it will develop some cracks around the edges
#92:  Author: ChristianRD PostPosted: Sat May 24, 2008 12:32 am
x 2
#93:  Author: pioneerLocation: Harmony|Chaos PostPosted: Sat May 24, 2008 12:34 am
I see Gopaul Lands hardware have a skil for $740 and Bhags have a B&D for $870
Both kinda "big"....was lookin for something small n neat
#94:  Author: (...Rovin...)Location: Chaguanas PostPosted: Sat May 24, 2008 12:35 am
by bhags should have a 2hp B&D which i also own - works alright though it can be made a bit nicer
but i rather use a jigsaw to cut out speaker holes - time it takes to set up a cutout jig i would have already cut out d hole ...invest in a good heavy duty jigsaw (like my dewalt) & good blades (like those from lennox) which makes d work easy .....
#95:  Author: pioneerLocation: Harmony|Chaos PostPosted: Sat May 24, 2008 12:50 am
Well reason i want a router is to do "rabitting" for fiberglass pods for speakers
But that B&D looks so huge for no reason Neutral
Is a rotozip any good?...could it do the same a router does?
#96:  Author: (...Rovin...)Location: Chaguanas PostPosted: Sat May 24, 2008 1:04 am
yeh d B&D kinda big\bulky
never used d rotozip b4 but i find its looking kinda too 'light duty' though i could be wrong - u cud buy a small mini router\laminate trimmer ...
#97:  Author: ChristianRD PostPosted: Sat May 24, 2008 1:11 am
I have ah rotozip with all d attachments and other trinkets. imo it lacks power but its good for small projects.
#98:  Author: pugboy PostPosted: Sat May 24, 2008 10:38 pm
Pioneer, the most common pro level small router is the Porter Cable 690
they also make a kit which can turn it into a plung router, the 690 has been around a very long time and is still the standard for small routers
routers are good tools, if you have the bushings you can make templates so the speaker is countersunk flush with the surface
for jigsaws the bosch progressor is the standard
toolless blade release and their blades last a very long time
You can make a good straight edge by laminating a pair of 1x4 dressed good quality lats, screwing them together and then taking them to a woodshop with a planer machine to straighten the edges, if they are properly glued/screwed they will not warp
Its not hard to build a makeshift tablesaw either, I have seen many carpenters bolt on a circular saw underneath to a 4x4 sheet of ply and make a fence to rip big sheets
the saw has to be parallel to the fence though otherwise the blade will bind
btw dewalt owns b&d or the other way around, they have both the pro and home market
#99:  Author: X_FactorLocation: St. Augustine PostPosted: Sat May 24, 2008 11:44 pm
ne body seen either SP120 or 175 on this link?...how much u guys think it will cost to bring in one of those?...i used the 175 today and thats the sweetest solder iron i ever used..
also for a heat gun..which u all recommend?..what brand and model, and where sells them?...i know someone told me about a ace hardware brand for 250?
#100:  Author: pioneerLocation: Harmony|Chaos PostPosted: Sun May 25, 2008 5:52 pm
How much for the porter cable 690 locally?
Page 5 of 15
